查看: 2006|回复: 3
[求助] 相噪仿真加入dff的veriloga模型,会报错
发表于 2023-12-21 20:14:01 | 显示全部楼层 |阅读模式
如题,时钟的相位噪声仿真中,我调用的ahdlib里的d_ff veriloga模型,会报错,有哪位大佬知道在哪里添加“ignore_hidden_state"嘛?
module d_ff(vin_d, vclk, vout_q, vout_qbar, reset, set);
input vclk, vin_d, reset, set;
output vout_q, vout_qbar;
electrical vout_q, vout_qbar, vclk, vin_d, reset, set;
parameter real vlogic_high = 5;
parameter real vlogic_low = 0;
parameter real vtrans_clk = 2.5;
parameter real vtrans = 2.5;
parameter real tdel = 3u from [0:inf);
parameter real trise = 1u from (0:inf);
parameter real tfall = 1u from (0:inf);
   integer x;
   analog begin
      @ (cross(V(vclk) - vtrans_clk, +1 ) or cross(V(reset) - vtrans_clk, +1 ) or cross(V(set) - vtrans_clk, +1 ) )
         if ( V(reset) > vtrans_clk )
         x = 0;
         else if ( V(set) > vtrans_clk )
         x = 1;
         else
         x = ( V(vin_d) > vtrans );
         V(vout_q) <+ transition( vlogic_high*x + vlogic_low*!x,
                                   tdel, trise, tfall );
         V(vout_qbar) <+ transition( vlogic_high*!x + vlogic_low*x,
    end
endmodule
发表于 2023-12-22 10:17:42 | 显示全部楼层
回复 支持 2 反对 0
 楼主| 发表于 2023-12-22 14:26:24 | 显示全部楼层
知道了,谢谢哥
发表于 2024-6-5 17:14:04 | 显示全部楼层
GMT+8, 2025-12-29 01:48 , Processed in 0.068062 second(s), 4 queries , Gzip On, Redis On.
