查看: 1735|回复: 2
[全新] 国产平替 16/20/24/32-bit 高精度 Σ-Δ 模数转换器芯片
发表于 2023-12-10 09:42:58 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。而且因为 fully compatible. 板子拿来,换个芯片,性能更好。MCU不用改 c code。
平替TI芯片
SIG1230A 平替 ADS1230 (20-bit)
SIG1232A 平替 ADS1232 (24-bit)
平替ADI芯片
SIG7190 平替 AD7190
SIG7192 平替 AD7192
SIG7193 平替 AD7193
平替Cirrus Logic芯片
SIG5532B 平替 CS5532BS(32-bit)
SIG5534B 平替 CS5534BS(32-bit)
SIG5532A 平替 CS5532AS(24-bit)
SIG5534A 平替 CS5534AS(24-bit)
SIG5530 平替 CS5530 (24-bit)
SIG5530B 平替 CS5530(32-bit)
平替ADI芯片
SIG7792 平替 AD7792
SIG7793 平替 AD7793
SIG7794 平替 AD7794
SIG7795 平替 AD7795
SIG7796 平替 AD7796
SIG7797 平替 AD7797
SIG7798 平替 AD7798
SIG7799 平替 AD7799
 楼主| 发表于 2024-1-18 16:11:39 | 显示全部楼层
性能更佳
SIG7792/SIG7793
4.17SPS to 890SPS ADC with PGA and Reference
Compatible Parts
AD7792/AD7793 pin/register fully compatible (10nV/℃ and 3ppm/℃).
Features
Programmable Gain: 1/2/4/8/16/32/64/128
Data Rates: 4.17SPS to 890SPS
RMS Noises: 20nV at 4.17SPS (Gain = 128)
23.2ENOB (21.0 noise-free bits) at 4.17SPS (Gain= 1)
Offset Drift: 5nV/℃ (Gain = 128)
Gain Drift: 1ppm/℃
Integral Non-linearity: 3ppm
internal reference: 4ppm/℃
Reference input current: 1uA
Internal or External Clock
Simultaneous 50Hz/60Hz Rejection
4 Differential Inputs
Current: 0.5mA
Specified Temperature Range: -40℃ to 125℃
Package: 16-ld TSSOP
Power Supply
AVDD: 2.7V to 5.25V
DVDD: 2.7V to 5.25V
Applications
Weight Scales and Strain Gauges
Flow/Pressure Measurement
Temeprature Measurement
Industrial Process Control
Medical Instrumentation
 楼主| 发表于 2023-12-10 09:44:26 | 显示全部楼层
16/20/24/32-bit 高精度 Σ-Δ 模数转换器芯片选型表
Product No.
Data Rate
PGA Gain
Resolution
Offset Drift
Gain Drift
Power
Package
Features
1.6SPS to 3840SPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-20
2 Differential Channels
1.6SPS to 3840SPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-24
4 Differential Channels
1.6SPS to 3840SPS
1/2/4/8/16/32/64
16-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
1.6SPS to 3840SPS
1/2/4/8/16/32/64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
1.6SPS to 3840SPS
1/2/4/8/16/32/64
16-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-24
1.6SPS to 3840SPS
1/2/4/8/16/32/64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-24
1.6SPS to 3840SPS
64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-20
1.6SPS to 3840SPS
64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
1.6SPS to 200SPS
64
24-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
4.0mA
TSSOP-20
1.6SPS to 30.72kSPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-20
1.6SPS to 30.72kSPS
1/2/4/8/16/32/64
32-bit
5nV/℃ (Gain = 64)
0.5ppm/℃
6.0mA
TSSOP-24
4.7SPS to 4.8kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
2.7mA
TSSOP-24
4 Single End Channels
4.7SPS to 4.8kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
2.7mA
TSSOP-24
4.7SPS to 4.8kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
2.7mA
TSSOP-28
8 Single End Channels
SIG7290
9.4SPS to 9.6kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
4.8mA
TSSOP-20
SIG7293
9.4SPS to 9.6kSPS
24-bit
3nV/℃ (Gain = 128)
0.5ppm/℃
4.8mA
TSSOP-24
4.17SPS to 890SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
4.17SPS to 890SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
4.17SPS to 890SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-24
6 Differential Channels
4.17SPS to 890SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-24
4.17SPS to 890SPS
128
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
4.17SPS to 890SPS
128
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
4.17SPS to 890SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
4.17SPS to 890SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.5mA
TSSOP-16
2.5SPS to 9600SPS
1/2/4/8/16/32/64/128/256
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-16
2.5SPS to 9600SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-20
2.5SPS to 9600SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-24
2.5SPS to 9600SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-16
2.5SPS to 9600SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-20
2.5SPS to 9600SPS
16-bit
5nV/℃ (Gain = 128)
1ppm/℃
0.8mA
TSSOP-24
10SPS to 2400SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.5mA
TSSOP-24
10SPS to 2400SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.5mA
TSSOP-16
1 Differential Channel
10SPS to 1200SPS
20-bit
10nV/℃ (Gain = 128)
2ppm/℃
0.8mA
TSSOP-16
10SPS/80SPS
1/2/64/128
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.5mA
TSSOP-24
10SPS/80SPS
64/128
20-bit
10nV/℃ (Gain = 128)
2ppm/℃
0.8mA
TSSOP-16
10SPS
64/128
20-bit
10nV/℃ (Gain = 128)
2ppm/℃
0.8mA
TSSOP-16
7.8SPS to 8000SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.3mA
TSSOP-16
7 Single End Channels
7.8SPS to 8000SPS
24-bit
5nV/℃ (Gain = 128)
1ppm/℃
1.3mA
TSSOP-24
7 Differential Channels
13 Single End Channels
GMT+8, 2025-12-14 02:29 , Processed in 0.013496 second(s), 5 queries , Gzip On, Redis On.
