查看: 1482|回复: 1
[求助] drc问题
发表于 2023-12-8 10:06:58 | 显示全部楼层 |阅读模式
smic40工艺,请教下各位这个报错什么意思啊?怎么解决呢
Maximum M5 area of merged low density windows must follow item (1) and (2).
The definition of low density window: window size 10um*10um, step size: 5um, density <1%
(1) Maximum area of merged low density window <= 6500um2, except merged low density windows width <= 30um.
(2) Maximum area of merged low density window <= 18500um2.
DRC only check the region with width of (checking window NOT above excluding region) >= 5um
DRC doesn't check INDMY region.
发表于 2023-12-8 17:58:11 | 显示全部楼层
首先定义low density window: size 10 step 5 , density < 1%
抓出这些窗口后要同时满足以下条件:
1.merge后的面积<=6500um2,或者>6500um2 且 merge 后的width<=30um
2.merge后的面积<=18500um2, 或者>18500um2 且 merge 后的width<=5um
看看你的报错属于哪种情况,对应修改
GMT+8, 2025-12-15 01:33 , Processed in 0.123111 second(s), 3 queries , Gzip On, Redis On.
