查看: 1809|回复: 7
[求助] 运放输入附加的两个管子是干啥的?
发表于 2023-12-1 16:08:50 | 显示全部楼层 |阅读模式
如图所示,输入对管的B和这两个管子的G、S、B连一起,如果仅仅减小VTH没必要额外加这两个管子吧,,,
发表于 2023-12-1 16:21:42 | 显示全部楼层
dummy
 楼主| 发表于 2023-12-1 16:33:15 | 显示全部楼层
额,看着不是,版图上BULK环分成两块,输入管那块左右各有一根dummy,而且和这两个管子之间用环隔开了
发表于 2023-12-1 18:40:46 | 显示全部楼层
发表于 2023-12-2 01:15:43 | 显示全部楼层
The picture is not very clear to me.
(1) If the gate is connected to i/o (because there is a resistor before the grounded gate device), the grounded gate device may work as "secondary ESD device" for CDM. Its body diode provide a ESD protection for diff-pair.
(2) Another idea is to use it for reliability to prevent PID (Plasma induced damage). If the path to gate is long, to improve accuracy and prevent PID, the P/N junction may provide a discharge path for the charge induced by PID
发表于 2023-12-2 05:08:15 | 显示全部楼层
if not dummy, could be just a sub-diode for antenna error
发表于 2023-12-2 12:07:56 | 显示全部楼层
如果是直接接了芯片外部的输入输出口的话,是为了ESD用的,保护差分对
 楼主| 发表于 2023-12-4 09:37:22 | 显示全部楼层
额,有可能,确实是PAD,不过这个是怎么个原理能请教一下吗
GMT+8, 2025-10-28 08:32 , Processed in 0.017199 second(s), 5 queries , Gzip On, Redis On.
