查看: 4430|回复: 6
[原创] 金属dummy的添加方法
发表于 2023-11-24 15:07:23 | 显示全部楼层 |阅读模式
//注释: 输入输出和相关设置
/* SWITCH DEFINITION START */
PRECISION                       20000
LAYOUT PRECISION                2000
LAYOUT MAGNIFY                  AUTO
//DRC CELL NAME YES CELL SPACE XFORM ALL
//LAYOUT SYSTEM GDSII
LAYOUT SYSTEM  OASIS
LAYOUT PATH "test.oasis"
LAYOUT PRIMARY "test"
//LAYOUT PATH "test_M4.oasis"
//LAYOUT PRIMARY "test_M4"
//**** DRC output
DRC RESULTS DATABASE "rep/DRC_RES_test.db"
DRC SUMMARY REPORT "rep/DRC_test.rep"  // HIER
DRC KEEP EMPTY NO
DRC CHECK TEXT ALL
DRC MAXIMUM RESULTS ALL
DRC MAXIMUM RESULTS NAR ALL
DFM DEFAULTS RDB MAXIMUM 100000
//DRC INCREMENTAL CONNECT YES
//注释 :用到的layer层定义
//**layer definition
LAYER PRBOUNDARY    10800    // P&R cell boundary layer for auto P&R purpose
LAYER MAP 108 DATATYPE 0 10800
LAYER Chip_Boundary           10825    // For Chip area definition
LAYER MAP 108 DATATYPE 250 10825
LAYER M4i        2004                // Metal4 layer
LAYER MAP 34 DATATYPE 401 2004        // Mapping (34;401) to 2004 for M4i
LAYER MAP 34 DATATYPE 402 2004        // Mapping (34;402) to 2004 for M4i
//smint
LAYER M4ired 20041
LAYER MAP 34 DATATYPE 401 20041        // Mapping (34;402) to 2004 for M4i
LAYER M4iblue 20042
LAYER MAP 34 DATATYPE 402 20042        // Mapping (34;402) to 2004 for M4i
LAYER DM4_O       2024
LAYER MAP 334 DATATYPE 401 2024        // Mapping (334;401) to 2024 for OPC_M4i, OPC dummy metal
LAYER MAP 334 DATATYPE 402 2024        // Mapping (334;402) to 2024 for OPC_M4i, OPC dummy metal
LAYER DUM4    2044                // Dummy Metal4
LAYER MAP 334 DATATYPE 411 2044        // Mapping (334;411) to 2044 for DUM4
LAYER MAP 334 DATATYPE 412 2044        // Mapping (334;412) to 2044 for DUM4
LAYER F_ZONE0  22050
LAYER F_ZONE1  22051
LAYER F_ZONE2  22052
LAYER F_ZONE3  22053
////注释 :窗口定义,这里窗口的定义最关键,新生成的dummy在窗口的0.0原点开始,且第一根为红色。所以在stdcell区域就要找到第一更是红色的M4,且离这个M4的间距为Y上移0.064的M的起点位置为窗口的原始位置
//**the location for the first  fillgen=red  dummy of (DM4_O)  is POLGON LL ,  the pitch is  0.084,and space is 0.064  between first  fillgen and M4(vdd/vss)
// mesured the space of between  the first red M4 in the stdcell region and  polygon org  coordinate .which is 0.064
//1.1
LAYOUT POLYGON 18  80.0 220.0  120.0 220.0  120.0 140.354  200.0 140.354  200.0 220.0  220.0 220.0  220.0 260.0  200.0 260.0  200.0 420.0  220.0 420.0 220.0 480.0  200.0 480.0  200.0 620.0  220.0 620.0  220.0 680.0  200.0 680.0  200.0 700.0   80.0 700.0 F_ZONE0 test
LAYOUT POLYGON 6 300.0  100.0   340.0  100.0   340.0   63.074  1020.0   63.074  1020.0  140.0   300.0  140.0 F_ZONE1 test
LAYOUT POLYGON 6 1160.0   63.074  1680.0   63.074  1680.0  100.0  1740.0  100.0  1740.0  140.0  1160.0  140.0 F_ZONE2 test
LAYOUT POLYGON 18 1720.0  200.0  1740.0  200.0  1740.0  148.334  1820.0  148.334  1820.0  180.0  1880.0  180.0  1880.0  680.0  1800.0  680.0  1800.0  820.0  1720.0  820.0
1720.0  760.0  1740.0  760.0  1740.0  740.0  1720.0  740.0  1720.0  580.0  1740.0  580.0  1740.0  240.0  1720.0  240.0 F_ZONE3 test
//注释,filler大小和filler所生产的位置定义
//***Fill shape
DFM SPEC FILL SHAPE "R0"
        RECTFILL 0 0 .5 .02    // FILL region length&width
//        SPACEY .064 M4i               // space to DM4_0
//        SPACEX .146 M4i               // space to DM4_0
//        SPACE 2 DUM4               // space to DM4_0
        STEP  0.146 0.19        //0.146 in x-direction, Y:0.19
//        OFFSET 0.19 0.03                // the step of shape "R1", step from 0.128 to 0.146
//        COLOR SCHEME CHECKER
        COLOR SCHEME ALTERNATEX                //(offset 0.1 0  & ALTERNATE)  setted  that the same color is  in  X axis
//**which layer  added fill shape
DFM SPEC FILL fillR0
        INSIDE OF LAYER F_ZONE0
        INITIAL FILLREGION
        FILLSHAPE OUTPUT "outR0" "R0"
DFM SPEC FILL fillR1                        // R0 is the same
        INSIDE OF LAYER F_ZONE1
        INITIAL FILLREGION
        FILLSHAPE OUTPUT "outR1" "R0"
DFM SPEC FILL fillR2
        INSIDE OF LAYER F_ZONE2
        INITIAL FILLREGION
        FILLSHAPE OUTPUT "outR2" "R0"
DFM SPEC FILL fillR3
        INSIDE OF LAYER F_ZONE3
        INITIAL FILLREGION
        FILLSHAPE OUTPUT "outR3" "R0"
//生产的filler做一些逻辑操作,涉及到新生成金属离旁边dummy要求的最大金属的间距,和怎么提取出来颜色 。且stdcell内部不涉及dummy via上下等,否则要做逻辑操作
//**** multiple color assignment
//fill_A = DFM FILL fillR1 "outR1" COLOR A
//fill_B = DFM FILL fillR1 "outR1" COLOR B
fill_G0 = DFM FILL fillR0 "outR0"
fill_G1 = DFM FILL fillR1 "outR1"
fill_G2 = DFM FILL fillR2 "outR2"
fill_G3 = DFM FILL fillR3 "outR3"
VARIABLE  Max_GDM4_TO_allM4 0.146
VARIABLE  Max_GDM4_TO_PGM4  0.064
//M4OS = GROW M4i RIGHT BY 0.146 LEFT BY 0.146 TOP BY 0.063 BOTTOM BY 0.063
M4OS1 = SIZE  M4i BY 0.063        // the space between M4i and fill is 0.064
M4OS = GROW M4OS1  RIGHT BY 0.083 LEFT BY 0.083                // the space between M4i/DM4 and  fillgen dummy (left/right :0.146 top/bottom is== 0.064)
fill_GN=  (OR fill_G0 fill_G1 fill_G2 fill_G3) NOT INTERACT M4OS
//*** dummy to fixed color
PM4ired = GROW M4ired TOP BY 0.084 BOTTOM BY 0.084
DDUM4 =  SIZE DUM4 BY 0.146
DDM4_O =  SIZE DM4_O BY 0.146
fill_A = PM4ired and fill_GN
fill_B = fill_GN NOT fill_A
fill_A_out = fill_A NOT INTERACT (OR fill_B  DDUM4 DDM4_O )   // filter interact with fill_B ,DDUM4 ,DDM4_O
fill_B_out = fill_B NOT INTERACT (OR fill_A  DDUM4 DDM4_O)
//***dummy fill is outputed and assigned data number
oas_out{
DFM RDB OASIS fillout_test.oas fill_A_out 334 401
DFM RDB OASIS fillout_test.oas fill_B_out 334 402
最后的makefile   :calibre -64 -drc -hier -hyper -turbo fillgen_file
发表于 2023-11-24 16:30:37 | 显示全部楼层
mark一下
发表于 2024-8-13 17:58:29 | 显示全部楼层
赞一个
发表于 2024-11-18 16:49:17 | 显示全部楼层
学习一下
 楼主| 发表于 2025-3-10 20:35:36 | 显示全部楼层
aaC:\Users\tangsimin\Desktop\DV
C:\Users\tangsimin\Desktop\SC
 楼主| 发表于 2025-3-10 20:36:50 | 显示全部楼层
Notice the presence of properties DV, DG, and DA:
\u2022 DV (Density value) \u2014 Density value of the window (to eight significant figures).
\u2022 DG (Density gradient) \u2014 Gradient value of the window if GRADIENT is specified.
\u2022 DA (Density area) \u2014 Area value of the window. It may either be followed by a numeric
value, or by a layer name and then a numeric value. With no layer name, it is the area of
the window and is always attached. Otherwise, a DA property is attached for each input
layer and is the layer name followed by its area in the window.
Properties can be mapped to colors for display in Calibre RVE. They can also be sent to a
histogram in Calibre RVE for analysis. See \u201cCreating Histograms and Colormaps\u201d in the
Calibre RVE User\u2019s Manual for details.
发表于 2025-10-17 13:26:48 | 显示全部楼层
正好需要,多谢分享~~
GMT+8, 2025-11-2 05:06 , Processed in 0.024118 second(s), 3 queries , Gzip On, Redis On.
