查看: 1661|回复: 0
[原创] 【报错解决】ERROR: [VRFC 10-3516] mismatch in closing label
发表于 2023-11-12 15:24:50 | 显示全部楼层 |阅读模式
**mismatch in closing label**
**mismatch in closing label 'nf_cpu'; expected 'nf_cpu_cpu'
关闭标签'nf_cpu'不匹配;预计“nf_cpu_cpu”**
```javascript
module nf_cpu_cpu
    parameter                   ver = "1.2"
    // clock and reset
    input   logic   [0  : 0]    clk,        // clk
    input   logic   [0  : 0]    resetn,     // resetn
    // instruction memory (IF)
    output  logic   [31 : 0]    addr_i,     // address instruction memory
    input   logic   [31 : 0]    rd_i,       // read instruction memory
    output  logic   [31 : 0]    wd_i,       // write instruction memory
    output  logic   [0  : 0]    we_i,       // write enable instruction memory signal
    output  logic   [1  : 0]    size_i,     // size for load/store instructions
    output  logic   [0  : 0]    req_i,      // request instruction memory signal
    input   logic   [0  : 0]    req_ack_i,  // request acknowledge instruction memory signal
    // data memory and other's
    output  logic   [31 : 0]    addr_dm,    // address data memory
    input   logic   [31 : 0]    rd_dm,      // read data memory
    output  logic   [31 : 0]    wd_dm,      // write data memory
    output  logic   [0  : 0]    we_dm,      // write enable data memory signal
    output  logic   [1  : 0]    size_dm,    // size for load/store instructions
    output  logic   [0  : 0]    req_dm,     // request data memory signal
    input   logic   [0  : 0]    req_ack_dm  // request acknowledge data memory signal
endmodule : nf_cpu
```javascript
endmodule : nf_cpu和一开始的名称不一致
```javascript
改为endmodule : nf_cpu_cpu和
GMT+8, 2025-12-17 08:22 , Processed in 0.010196 second(s), 3 queries , Gzip On, Redis On.
