查看: 3854|回复: 4
瞬态仿真遇到的问题,仿真跑不起来。
发表于 2023-10-26 10:02:31 | 显示全部楼层 |阅读模式
Internal error found in spectre during IC analysis, during transient analysis `tran'.
Encountered a critical error during simulation. Please run `mmsimpack' to pack the test case (use mmsimpack -h option to get detailed usage), and submit the case via Cadence Online Support, including the package tar file and any other information that can help identify the problem.
    FATAL (SPECTRE-18): Segmentation fault.
求大神指导,感谢。
发表于 2023-10-27 13:41:35 | 显示全部楼层
mmsim这年头不都是spectre了吗
发表于 2023-11-1 10:59:35 | 显示全部楼层
蹲个后续
 楼主| 发表于 2023-11-13 15:55:01 | 显示全部楼层
问题已解决,虚拟机内存不足,清理一下可以了
发表于 2023-11-14 01:43:03 | 显示全部楼层
good to know, thanks
GMT+8, 2025-12-28 09:39 , Processed in 0.016105 second(s), 3 queries , Gzip On, Redis On.
