查看: 1529|回复: 3
[求助] 建立时间的公式
发表于 2023-10-17 11:44:20 | 显示全部楼层 |阅读模式
请问这个公式是怎么推导出来的,有没有大哥能帮忙解答一下??
发表于 2023-10-17 14:05:00 | 显示全部楼层
since the input is a large signal, you will see the circuit slew first, which will then become linear at a certain point (see the context where an assumption is made).
1. use slewing to calculate the first time
2. use the linear model (i.e. small signal model) to calculate the second time.
3. Rls=first time/second time
发表于 2023-10-17 16:11:04 | 显示全部楼层
icdane 发表于 2023-10-17 14:05
since the input is a large signal, you will see the circuit slew first, which will then become linea ...
i see
 楼主| 发表于 2023-10-25 15:28:32 | 显示全部楼层
thanks
GMT+8, 2025-12-22 12:18 , Processed in 0.042992 second(s), 4 queries , Gzip On, Redis On.
