查看: 2751|回复: 6
IC618无法启动explorer和assembler
发表于 2023-10-7 15:45:09 | 显示全部楼层 |阅读模式
新建cell时virtuoso崩溃,报错日志如下
Loading simui.cxt
\e *Error* error: Timed out attempting to connect to launched beanstalkd process. - nil
\w *WARNING* (DEBASE-102079): A SKILL error occurred in function _axlDataTrigger
\w *WARNING* (DEBASE-102084): Data trigger for viewType maestro failed.
\r "rightViewType"
\o Loading viva.cxt
\o Error: Received an unexpected system exception: Timed out attempting to connect to launched beanstalkd process..
\o If you are unable to isolate the problem, contact your Cadence Customer Support representative for help.
发表于 2023-10-7 15:56:56 | 显示全部楼层
可能是PDK的某个skill权限不够
 楼主| 发表于 2023-10-7 16:32:28 | 显示全部楼层
请问如何解决这个权限问题,不太了解还望指教!
 楼主| 发表于 2023-10-7 16:37:45 | 显示全部楼层
liudin 发表于 2023-10-7 15:56
可能是PDK的某个skill权限不够
请问如何排查这个问题,不太了解,请多指教!
发表于 2023-10-8 10:35:23 | 显示全部楼层
可以通过命令行run 来排查,报错一目了然
发表于 2024-11-18 17:28:40 来自手机 | 显示全部楼层
楼主知道怎么解决上面这个问题了么?
发表于 2025-7-19 02:34:13 | 显示全部楼层
遇到了同样的问题,是怎么解决的?
GMT+8, 2025-12-26 12:23 , Processed in 0.016084 second(s), 3 queries , Gzip On, Redis On.
