查看: 862|回复: 0
[求助] DC综合不通过显示Warning: Value of function 'max1' is used before being assigned
发表于 2023-10-5 16:54:24 | 显示全部楼层 |阅读模式
我在sv中声明一个函数后调用,编译仿真可以通过,但在DC综合时显示
Warning:  ../../rtl_tile8x8_new/Tile.sv:181: Value of function 'max1' is used before being assigned; the synthesized result may not match simulations. (ELAB-393)
然后导致错误
Error:  ../../rtl_tile8x8_new/Tile.sv:181: Internal error.  (VER-37)
该如何解决?
GMT+8, 2025-12-30 09:36 , Processed in 0.011869 second(s), 5 queries , Gzip On, Redis On.
