查看: 1586|回复: 5
[求助] tessent错误:there are unsaved module……
发表于 2023-9-26 09:22:28 来自手机 | 显示全部楼层 |阅读模式
there are unsaved modules…怎么修改上树错误呢
发表于 2023-9-26 10:14:14 | 显示全部楼层
rtl级insertion模式下改了电路,需要保存电路,看你需不需要保存这些修改,不需要的话加-force,set_system_mode {setup | insertion | analysis} [-force]
 楼主| 发表于 2023-9-26 10:25:09 来自手机 | 显示全部楼层
你好,改了电路是指工具改了电路对吧,如果我需要保存电路该怎么办呢
发表于 2023-9-26 10:40:22 | 显示全部楼层
INSERTION> set_system_mode setup //  Error: The design has modified modules which were not saved. //         Either use the restore_design command to discard the edits or save them using write_design. //         Use [get_modules -filter is_unsaved] if you want to see the unsaved modules.
发表于 2023-9-26 10:42:59 | 显示全部楼层
write_design -original_location option
 楼主| 发表于 2023-9-26 10:58:57 来自手机 | 显示全部楼层
谢谢
GMT+8, 2025-12-31 02:55 , Processed in 0.016828 second(s), 4 queries , Gzip On, Redis On.
