查看: 3372|回复: 6
[求助] 采用ADE_XL进行蒙特卡洛仿真时,仿真太慢,出现以下错误,怎么解决呢???急!!!
发表于 2023-9-3 10:58:00 | 显示全部楼层 |阅读模式
悬赏20资产未解决
 楼主| 发表于 2023-9-3 14:20:20 | 显示全部楼层
WARNING (ADE-7002): The Spectre run mode needs to be 'batch' when Spectre high-performance mode is enabled. Automatically             setting the run mode to 'batch'. Loading elec.cxt  Loading vqp.cxt  WARNING (ADE-7002): The Spectre run mode needs to be 'batch' when Spectre high-performance mode is enabled. Automatically             setting the run mode to 'batch'. ERROR (ADEXL-2220): While initializing the results database, the SQL pragma "legacy_file_format" with value "ON" could not be applied onto the results database engine Return value is: "" The results database uses SQL statements internally. ADE XL will continue to function but will operate slower than expected. Contact Cadence Customer Support to report the problem.  WARNING (ADE-7002): The Spectre run mode needs to be 'batch' when Spectre high-performance mode is enabled. Automatically             setting the run mode to 'batch'. Loading monte.cxt  Loading stats.cxt  Loading paraplot.cxt  Loading adpServer.cxt  ERROR (ADEXL-2220): While initializing the results database, the SQL pragma "legacy_file_format" with value "ON" could not be applied onto the results database engine Return value is: "" The results database uses SQL statements internally. ADE XL will continue to function but will operate slower than expected. Contact Cadence Customer Support to report the problem.
 楼主| 发表于 2023-9-3 14:24:15 | 显示全部楼层
DeerYC 发表于 2023-9-3 14:20
WARNING (ADE-7002): The Spectre run mode needs to be 'batch' when Spectre high-performance mode is e ...
报错显示这个“legacy_file_format" with value "ON",导致ADEXL的速度会变慢,好慢啊,怎么能修改这个参数的值呢?
 楼主| 发表于 2023-9-3 14:25:38 | 显示全部楼层
就是这个报错,显示这个参数 "legacy_file_format" with value "ON" ,导致ADEXL仿真缓慢。。。怎么能改变这个参数的值呢?
发表于 2024-1-13 23:08:38 | 显示全部楼层
请问解决了吗
 楼主| 发表于 2024-1-29 19:58:28 | 显示全部楼层
允执其中 发表于 2024-1-13 23:08
请问解决了吗
没解决,找不到解决办法,重新弄一个系统和软件吧
发表于 2024-7-7 23:07:04 | 显示全部楼层
真的只能弄一个软件吗
GMT+8, 2025-11-4 16:24 , Processed in 0.112100 second(s), 5 queries , Gzip On, Redis On.
