查看: 2070|回复: 3
[求助] a question about ansys totem ir drop analysis.
发表于 2023-8-25 18:05:32 | 显示全部楼层 |阅读模式
1. To see the IR drop, which analysis should be performed?
2. Can I see ir drop in static analysis?
3. Please tell me the reason why def and lef are duplicated in the gsr file in the dynamic analysis.
4. Is a library file (.lib) required to characterize blocks in dynamic analysis?
5. Should I extract the STA timing by verilog modeling the Analog Block in the dynamic analysis? So, can I see the full IR drop in the dynamic analysis?
6. Do I really need to put the lumped model of the pad in dynamic.tcl?
setup package -power -r 0.005 -l 1 -c 5
setup package -ground -r 0.005 -l 1 -c 5
setup wirebond -power -r 0.01 -l 2.2 -c 1.42 -ground -r 0.05 -l 1.7 -c 0.2
setup pad -power -r 0.001
setup pad -ground -r 0.001
7. Please tell me the options that must be included in Ansys Totem dynamic analysis.
发表于 2023-10-10 11:46:57 | 显示全部楼层
发表于 2023-10-10 11:47:49 | 显示全部楼层
static and dynamic analysis all can check IR Drop
发表于 2023-10-10 11:54:28 | 显示全部楼层
-->they are two different circuit description format, totem can parse circuit base on them
-->what's format about library file?you'd better show am example to us
--> STA file is an optional, yes, we can see power and signal EMIR drop in dynamic analysis
GMT+8, 2025-12-21 18:35 , Processed in 0.015975 second(s), 4 queries , Gzip On, Redis On.
