查看: 1707|回复: 0
a question about ansys totem ir drop analysis.
发表于 2023-8-25 17:59:47 | 显示全部楼层 |阅读模式
1. To see the IR drop, which analysis should be performed?
2. Can I see ir drop in static analysis?
3. Please tell me the reason why def and lef are duplicated in the gsr file in the dynamic analysis.
4. Is a library file (.lib) required to characterize blocks in dynamic analysis?
5. Should I extract the STA timing by verilog modeling the Analog Block in the dynamic analysis? So, can I see the full IR drop in the dynamic analysis?
6. Do I really need to put the lumped model of the pad in dynamic.tcl?
setup package -power -r 0.005 -l 1 -c 5
setup package -ground -r 0.005 -l 1 -c 5
setup wirebond -power -r 0.01 -l 2.2 -c 1.42 -ground -r 0.05 -l 1.7 -c 0.2
setup pad -power -r 0.001
setup pad -ground -r 0.001
7. Please tell me the options that must be included in Ansys Totem dynamic analysis.
GMT+8, 2025-12-21 18:34 , Processed in 0.016026 second(s), 4 queries , Gzip On, Redis On.
