查看: 4340|回复: 13
C* 家 RAK 求助
发表于 2023-8-16 14:43:12 | 显示全部楼层 |阅读模式
悬赏100资产已解决
有大佬可以好心提供下vMan_SVRNM_SVA ,这个RAK吗?
最佳答案
查看完整内容
A RF Transceiver Model is used to demonstrate the use of vManager to verify a complex mixed signal system. Verification is driven by a UVM test bench and includes SystemVerilog coverage, SystemVerilog assertions, and a UVM scoreboard. The system under test is modeled with Real Number Digital Mixed Signal constructs.Digital Mixed Signal representations of your complex mixed signal system can fit s ...
发表于 2023-8-16 14:43:13 | 显示全部楼层
Digital Mixed Signal representations of your complex mixed signal system can fit seamlessly into your digital verification strategy using vManager to oversee all stages of verification. This training resource, videos, quick start guide, presentations and testcase example demonstrate how to include functional verification system simulations into a vManager verification plan. The system under test for this demonstration is a low power ISM band RF Transceiver. SystemVerilog assertions and covergroups are utilized, and a UVM testbench including a scoreboard drives the system tests. Interaction with the vManager GUI and with the web interface is shown.
Please look into other tabs of this knowledge resource page for videos (Part-1 and Part-2) and other associated learning resources and the example database
  • Quick Start Guide
  • Transceiver Real Number Model Functional Specification
  • Presentation Tour
  • UVM Presentation - Application of UVM Verification Methodology to a Behaviorally Modeled Radio Frequency Transceiver System
  • Testcase Example Database
Quick Start Guide.pdf (203.4 KB , 下载次数: 106 )
UVM_for_RF_Transceiver.pdf (844.49 KB , 下载次数: 106 )
vMan_SVRNM_SVA.pdf (822.97 KB , 下载次数: 106 )
Transceiver RNM Functional Specification.pdf (803.91 KB , 下载次数: 104 )
vMan_SVRNM_SVA.tar.gz (160.28 KB , 下载次数: 113 )
 楼主| 发表于 2023-8-16 17:37:00 | 显示全部楼层
11111111
发表于 2023-8-17 21:12:35 | 显示全部楼层
同求帮顶
 楼主| 发表于 2023-8-21 09:12:06 | 显示全部楼层
kk2009 发表于 2023-8-19 11:17
A RF Transceiver Model is used to demonstrate the use of vManager to verify a complex mixed signal  ...
感谢!!!!!!
发表于 2023-8-23 13:39:36 | 显示全部楼层
厉害了
 楼主| 发表于 2023-8-23 14:37:01 | 显示全部楼层
已解决!!
发表于 2023-8-25 08:56:36 | 显示全部楼层
补全了
以前只有这个 MDV_FLOW
 楼主| 发表于 2024-1-23 20:20:30 | 显示全部楼层
你好!今天发现RAK ,verilog 目录下好像少了个文件,最近刚好要用到这部分功能!方便的话能否帮忙确认下是否遗露,还是本来就没有?
非常感谢!!!
发表于 2024-1-24 08:47:23 | 显示全部楼层
Thanks for sharing...
GMT+8, 2025-9-16 03:33 , Processed in 0.021965 second(s), 6 queries , Gzip On, Redis On.
