查看: 4938|回复: 25
Aldec Riviera Simulation Error
发表于 2023-8-14 07:11:47 | 显示全部楼层 |阅读模式
Whatever I do, I get simulation error. The Testbench can't instantiate modules inside it and can't connect to them so can't access to their internal structures. This is the reason I always get error in the waveform (Output signals are always Z or U).
Have you been able to solve this big problem?
It practically doesn't allow any project to be simulated.
I have the same simulation error in all versions of the patched Riviera.
发表于 2023-8-17 21:44:27 | 显示全部楼层
破解设置不完整引起
 楼主| 发表于 2023-8-18 00:31:49 | 显示全部楼层
asaa 发表于 2023-8-17 21:44
破解设置不完整引起
Do you know how to resolve this issue?
发表于 2023-8-20 18:43:29 | 显示全部楼层
v2017
发表于 2023-8-20 19:00:09 | 显示全部楼层
asaa 发表于 2023-8-20 18:43
一直用windows版本v2017,没有其他版本,应该类似
没有闪退现象吗?
发表于 2023-8-22 00:39:19 | 显示全部楼层
Sir, can you please share Aldec Riviera software with me? I shall be very thankful to you
 楼主| 发表于 2023-8-29 06:42:20 | 显示全部楼层
None of the patched versions works. All of the simulations in them are wrong. Needs another robust patch.
发表于 2023-8-29 18:35:32 | 显示全部楼层
有高版本吗,低版本sv支持不全
 楼主| 发表于 2023-8-30 00:21:12 | 显示全部楼层
asaa 发表于 2023-8-29 18:35
有高版本吗,低版本sv支持不全
None of the versions work. All of them give wrong simulation results.
发表于 2023-8-30 19:46:19 | 显示全部楼层
https://allpcworlds.com/download-aldec-riviera-pro-2014-free/
GMT+8, 2025-12-18 23:00 , Processed in 0.018351 second(s), 3 queries , Gzip On, Redis On.
