查看: 1947|回复: 4
[求助] iVerilog和VCS的仿真结果不一致?
发表于 2023-8-13 09:54:27 | 显示全部楼层 |阅读模式
大家好,我最近在测试一个设计,发现iverilog和vcs仿真结果不一致的问题。
vcs的对 <= 的处理有问题, 请大伙看看,这是一个真的问题吗?
举一个简单的例子,使用一个小设计adder:
Verilog code:
  1. module top(input wire clk, input wire [27:0] io_in, output wire [27:0] io_out, io_oeb);
  2.         wire rst = io_in[0];
  3.         reg [15:0] ctr;
  4.         always @(posedge clk)
  5.                 if (rst)
  6.                         ctr <= 0;
  7.                 else
  8.                         ctr <= ctr + 1'b1;
  9.         assign io_out = {10'h123, ctr, rst, 1'b0}; // pass thru reset for debugging
  10.         assign io_oeb = 28'b1;
  11. endmodule
    复制代码
testbench in iverilog:
  1. `timescale 1ps/1ps
  2. module fab_tb;
  3.     wire [27:0] I_top;
  4.     wire [27:0] T_top;
  5.     reg [27:0] O_top = 0;
  6.     reg CLK = 1'b0;
  7.     wire [27:0] I_top_gold, oeb_gold, T_top_gold;
  8.     top dut_i (
  9.         .clk(CLK),
  10.         .io_out(I_top_gold),
  11.         .io_oeb(oeb_gold),
  12.         .io_in(O_top)
  13.     );
  14.     assign T_top_gold = ~oeb_gold;
  15.     always #50 CLK = (CLK === 1'b0);
  16.     integer i;
  17.     reg have_errors = 1'b0;
  18.     initial begin
  19.         repeat (100) @(posedge CLK);
  20.         O_top = 28'b1; // reset
  21.         repeat (5) @(posedge CLK);
  22.         O_top = 28'b0;
  23.         for (i = 0; i < 100; i = i + 1) begin
  24.             @(negedge CLK);
  25.             $display("cnt  = 0x%X, f gold = 0x%X,  gold = 0x%X", O_top, I_top_gold, T_top_gold);
  26.         end
  27.         if (have_errors)
  28.             $fatal;
  29.         else
  30.             $finish;
  31.     end
  32.
  33.     initial begin
  34.             $dumpfile("wave.vcd");        //
  35.             $dumpvars(0, fab_tb);
  36.
  37.     end
  38. endmodule
  39. module clk_buf(input A, output X);
  40. assign X = A;
  41. endmodule
  42.
    复制代码
testbench in vcs:
  1. module adder_tb;
  2.     wire [27:0] I_top;
  3.     wire [27:0] T_top;
  4.     reg [27:0] O_top = 0;
  5.     reg CLK  = 1'b1;
  6.     wire [27:0] I_top_gold, oeb_gold, T_top_gold;
  7.     top dut_i (
  8.         .clk(CLK),
  9.         .io_out(I_top_gold),
  10.         .io_oeb(oeb_gold),
  11.         .io_in(O_top)
  12.     );
  13.     assign T_top_gold = ~oeb_gold;
  14.     always #50 CLK = (CLK === 1'b0);
  15.     //always begin
  16.         //#50
  17.         //CLK = ~CLK;
  18.     //end
  19.     //always #50 CLK = ~CLK ;
  20.     integer i;
  21.     reg have_errors = 1'b0;
  22.     initial begin
  23.         repeat (100) @(posedge CLK);
  24.         O_top = 28'b1; // reset
  25.         repeat (5) @(posedge CLK);
  26.         O_top = 28'b0;
  27.         //repeat (50) @(posedge CLK);
  28.         //$display("in_in = 0x%X, gold = 0x%X, gold = 0x%X", O_top, I_top_gold, T_top_gold);
  29.         for (i = 0; i < 100; i = i + 1) begin
  30.             @(negedge CLK);
  31.             $display("in_in = 0x%X, gold = 0x%X, gold = 0x%X", CLK, I_top_gold, T_top_gold);
  32.         end
  33.         if (have_errors)
  34.             $fatal;
  35.         else
  36.             $finish;
  37.     end
  38.         initial begin
  39.                 $fsdbDumpfile("adder_tb.fsdb");  //
  40.                 $fsdbDumpvars(0,adder_tb);       //
  41.                 //$fsdbDumpSVA();
  42.                 //$fsdbDumpMDA();
  43.                 //$vcdpluson;
  44.                 //$vcdplusmemon;
  45.         end
  46. endmodule
  47. module clk_buf(input A, output X);
  48. assign X = A;
  49. endmodule
  50.
    复制代码
iverilog_GtkWave结果(我认为是正确的):
VCS+Verdi:
iverilog+GtkWave
iverilog+GtkWave
VCS+Verdi
VCS+Verdi
发表于 2023-8-14 09:53:11 | 显示全部楼层
always @(posedge clk or posedge rst)  ,这样子试一下
 楼主| 发表于 2023-8-14 12:27:41 | 显示全部楼层
谢谢大佬,但是刚刚试了下,还是同样的结果
发表于 2023-8-15 07:17:42 | 显示全部楼层
#0 O_top = 28'b0;
試試
 楼主| 发表于 2023-8-15 23:38:36 | 显示全部楼层
jasper0608 发表于 2023-8-15 07:17
#0 O_top = 28'b0;
試試
真的可以!谢谢大佬
GMT+8, 2025-12-28 23:26 , Processed in 0.021006 second(s), 4 queries , Gzip On, Redis On.
