查看: 2341|回复: 2
[求助] virtuoso仿真报错
发表于 2023-8-7 16:36:47 | 显示全部楼层 |阅读模式
想请教一下,我把库导入后仿真报错SFS868找不见路径怎么解决呢
ERROR (SFE-868): "input.scs" 8: Can not open input file `/mnt/hgfs/Common'. No such file or directory. Ensure that the file exists and the path to the file is correct. Otherwise, use the -I<path> command-line option to specify the path to the file.
报错界面
报错界面
发表于 2024-7-26 00:23:08 | 显示全部楼层
同求,题主后面有找到啥解决的办法不
发表于 2024-7-26 14:35:57 | 显示全部楼层
文件位置不对
GMT+8, 2025-12-25 21:17 , Processed in 0.024144 second(s), 6 queries , Gzip On, Redis On.
