查看: 3012|回复: 3
[求助] 数字综合版图,cds thru导致lvs不通过
发表于 2023-8-4 10:44:29 | 显示全部楼层 |阅读模式
悬赏300资产未解决
最近通过写代码的方式生成版图,代码里有一对输入和输出端口逻辑上一直是1和0同步变化(属于巧合),因此软件综合的时候在二者之间加上了cds thru来防止短路然后接在了一起。但是这样综合的结果版图lvs过不了,显示找不到对应的pin。这样的问题有人知道如何解决吗,急求呀
 楼主| 发表于 2023-8-4 10:45:17 | 显示全部楼层
图片在此
发表于 2023-8-4 10:51:20 | 显示全部楼层
转自cadence forum,原创回答:Andrew Beckett
Problem
The cds_thru device from the "basic" library is used when it is required to join up 2 different pins in a schematic (.e.g to join up a VSSA net to a VSS net). How can an LVS mismatch due to this extra device be resolved?
Solution
The LVS mismatch can be resolved as follows:
=== Assura ===
avCompareRules(
   schematic(
      filterDevice("cds_thru" short("src" "dst"))
   ) ;schematic
) ;avCompareRules
Using the above command, Assura will filter the cds_thru device from the schematic and short the 2 terminals. The net connecting to the 1st terminal specified in the command will be retained. For the above example, it will be the net connecting to the "src" terminal.
For a CDL netlist input, the command would be:
avCompareRules(
   schematic(
      filterDevice( "SH" short("src" "dst"))
   ) ;schematic
) ;avCompareRules
cds_thru is exported to a CDL netlist as a resistor with the model "SH" and resistance 0.1 ohms. Alternatively, the following CDL control command can be used in the CDL netlist:
*.RESI 2000
The above means that resistors with R values of 2000 and below will be automatically shorted.
=== PVS ===
lvs_filter_device R(SH) -short -source
=== Calibre ===
LVS FILTER R(SH) SHORT SOURCE
 楼主| 发表于 2023-8-4 14:09:18 | 显示全部楼层
Problem
谢谢!我去看下
GMT+8, 2025-10-22 03:56 , Processed in 0.014226 second(s), 4 queries , Gzip On, Redis On.
