楼主: FOREVER10
[其它] 调节metal 线宽和via个数的skill脚本(virtuoso)
发表于 2024-1-9 17:13:55 | 显示全部楼层
FOREVER10 发表于 2024-1-9 17:06
不是,就是你这个脚本存放的路径 即可。
嗯嗯,感谢大佬
发表于 2024-1-14 09:07:57 | 显示全部楼层
謝謝,ˋ有點可惜被加密了~
发表于 2024-1-16 16:51:38 | 显示全部楼层
这快捷键不容易冲突,好用
 楼主| 发表于 2024-2-28 14:13:13 | 显示全部楼层
785449525 发表于 2024-1-16 16:51
这快捷键不容易冲突,好用
是的,而且 +- 这个也很直观
发表于 2024-7-30 22:26:52 | 显示全部楼层
ljh065216 发表于 2023-8-2 09:21
是否可以不加密,方便改快捷键
(procedure((TMYpathadderrinf)
        hiDisplayAppDBox(?name
            gensym('GridlogBox) ?dboxBanner "Check Your Selection" ?dboxText
            patherr ?dialogType hicWarningDialog ?dialogStyle
            'modal
            ?buttonLayout
            'Close
)(procedure((TMCpathwidthtoggleminus)
        (TMCREADONLY)
        let((cv geseltype pthresul pthsegresul selgroupID
                newpath
            geSelObjectsPartiallySelected()
            (cv = geGetEditCellView())
            if((ref == nil) then
                sprintf(patherr "No object is selected.")
                (TMYpathadderrinf) else
                (geseltype = (ref~>objType))
                (pthresul = setof(xx geseltype
                        (xx != "path")
                if((pthresul == nil) then
                    cond(((car(geseltype) == "path")
                            let((pthlaynmlst pthpurposelst pthpointslst pthwidthlst pthnetnmlst
                                    pthpointslst pthlaynmlst newpath pthwidthlst x
                                    y z a
                                (pthlaynmlst = (ref~>layerName))
                                (pthpurposelst = (ref~>purpose))
                                (pthpointslst = (ref~>points))
                                (pthwidthlst = (ref~>width))
                                (pthnetnmlst = ((ref~>net)~>name))
                                (selgroupID = leGetEditFigGroup((getCurrentWindow)))
                                foreach((x y z a) pthpointslst pthlaynmlst ref pthwidthlst
                                    (newpath = dbCreatePath(cv
                                            list(y
                                                car(pthpurposelst)
                                            car(list(x))
                                            (a - 0.01)
                                    geSelectObject(newpath)
                                    dbDeleteObject(z)
                                if((selgroupID != nil) then
                                    dbAddFigToFigGroup(selgroupID newpath)
                                printf(" ")
                    ) else
                    sprintf(patherr "Warning: Only path could be selected, please check.")
                    (TMYpathadderrinf)
)(hiSetBindKey("Layout" "<Key>KP_Subtract" "TMCpathwidthtoggleminus()"))(
            'modal
            ?buttonLayout
            'Close
)(procedure((TMCpathwidthtoggleplus)
        (TMCREADONLY)
                newpath
                        (xx != "path")
                                    y z a
                                            list(y
                                                car(pthpurposelst)
                                            car(list(x))
                                            (a + 0.01)
                                    dbDeleteObject(z)
                                printf(" ")
                    ) else
                    (TMYpathadderrinf)
)(hiSetBindKey("Layout" "<Key>KP_Add" "TMCpathwidthtoggleplus()"))(
    procedure((TMCREADONLY)
        let((cv cellname libname n20)
            if(((geGetEditCellView()~>mode) == "r") then
                (cv = geGetWindowCellView())
                (cellname = (cv~>cellName))
                (libname = (cv~>libName))
                sprintf(n20 "\nYou couldn't run this edit command becasue (  cell: %s   lib: %s  ) layout view is currentlly in read mode.\nRun the command agian after openning the cellview in edit mode.\nAny question, don't hesitate to contact Tomic.\n\n" cellname libname)
                printf(n20)
                    gensym('trReminderDialogBox) ?dboxBanner "Layout Read Only" ?dboxText
                    n20 ?dialogType hicErrorDialog ?dialogStyle
                    'modal
                    ?buttonLayout
                    'UserDefined ?buttons
                    '("Make Editable" "Close") ?callback
                    '("TMCToggleEditReadMode()" "")
                break()
)(procedure((TMCviaColRows ref deltaRow deltaCol \@optional
            (doVerbose nil) "dnng"
        (TMCREADONLY)
        let((techId mid viaHead viaParams row
                col newVia
                (thefun "TMCviaColRow")
            unless(((ref~>objType) == "stdVia")
                error("%s:ERR00: Please select a standard via\n" thefun)
            when(member((ref~>orient)
                    list("R90" "R270" "MYR90" "MXR90")
                (row = deltaRow)
                (deltaRow = deltaCol)
                (deltaCol = row)
                when(doVerbose
                    info("[%s] Rotated - row=%L ; col=%L\n" thefun deltaRow deltaCol)
            (techId = techGetTechFile((ref~>cellView)))
            (viaHead = (ref~>viaHeader))
            (mid = techFindViaDefByName(techId
                    (viaHead~>viaDefName)
            (row = max(1
                    (nth(3
                            ((viaHead~>viaDef)~>params)
                        ) + deltaRow)
            (col = max(1
                    (nth(4
                        ) + deltaCol)
            foreach(par
                (viaHead~>overrideParams)
                case(car(par)
                    ("cutRows"
                        (row = max(1
                                (cadr(par) + deltaRow)
                        (viaParams = cons(list("cutRows" row) viaParams))
                        (row = nil)
                    ("cutColumns"
                        (col = max(1
                                (cadr(par) + deltaCol)
                        (viaParams = cons(list("cutColumns" col) viaParams))
                        (col = nil)
                    (t
                        (viaParams = cons(par viaParams))
            when(row
            when(col
            (newVia = dbCreateVia((ref~>cellView) mid
                    (ref~>xy)
                    (ref~>orient) viaParams
            if(dbobjectp(newVia) then
                dbDeleteObject(ref)
                geSelectObject(newVia) else
                error("%s:ERR01: Problem during via creation\n" thefun)
            if((selgroupID == nil) then newVia else
                dbAddFigToFigGroup(selgroupID newVia)
)(procedure((TMCviaColRow viaList deltaRow deltaCol)
        let(nil
            (viaList = setof(via viaList
                    ((via~>objType) == "stdVia")
            foreach(via viaList
                (TMCviaColRows via deltaRow deltaCol)
)(procedure((tmc_toggle_obj_minus)
        let((objsel viaone)
            (objsel = geGetSelSet())
            if((objsel == nil) then
                sprintf(patherr "Warning: No object is selected, please check.")
                (TMYpathadderrinf)
                printf("%s\n\n" patherr)
                else
                foreach(Object objsel
                    if((((Object~>objType) == "path") || ((Object~>objType) == "stdVia")) then
                        cond((((Object~>objType) == "path")
                                (ref = list(Object))
                            (((Object~>objType) == "stdVia")
                                (viaone = list(Object))
                                (TMCviaColRow viaone 0 -1)
                        ) else
                        sprintf(patherr "Warning: Only path/via could be selected to toggle width/number, please check.")
                        (TMYpathadderrinf)
                        break()
                printf("\nMinus one number/grid.")
)(hiSetBindKey("Layout" "<Key>-" "tmc_toggle_obj_minus()"))(
    procedure((tmc_toggle_obj_plus)
        let((objsel viaone)
                (TMYpathadderrinf)
                else
                                (TMCviaColRow viaone 0 1)
                        ) else
                        (TMYpathadderrinf)
                        break()
                printf("\nPlus one number/grid.")
)(hiSetBindKey("Layout" "<Key>=" "tmc_toggle_obj_plus()"))(
    procedure((TMCToggleEditReadMode)
        let((cellnm viewnm libnm lockinfo outinfo)
                (cellnm = (geGetEditCellView()~>cellName))
                (viewnm = (geGetEditCellView()~>viewName))
                (libnm = (geGetEditCellView()~>libName))
                (lockinfo = geGetLockInfo(libnm cellnm viewnm))
                if((lockinfo != "(no data on lock available)") then
                    sprintf(outinfo "%s/%s/%s is locked by %s." libnm cellnm viewnm
                        lockinfo
                        gensym('GridlogBox) ?dboxBanner "Layout Locked" ?dboxText
                        outinfo ?dialogType hicWarningDialog ?dialogStyle
                        'modal
                        ?buttonLayout
                        'Close
                    printf(outinfo)
        case((geGetEditCellView()~>mode)
            ("a"
                geChangeEditMode("r")
            ("r"
                geChangeEditMode("a")
)(hiSetBindKey("Layout" "Super<Key>e" "TMCToggleEditReadMode()"))(
    hiSetBindKey("Layout" "<Key>+" "TMCviaColRow( geGetSelSet()  1  0 )")
)(hiSetBindKey("Layout" "<Key>_" "TMCviaColRow( geGetSelSet() -1  0 )"))
发表于 2024-9-4 11:29:54 | 显示全部楼层
            gensym('GridlogBox) ?dboxBanner "Chec ...
大佬你是解密出来的吗?我想看看pdk里面pcell怎么写的,这个也可以解密吗?
发表于 2024-9-7 15:55:41 | 显示全部楼层
load这个有问题
发表于 2024-10-15 13:36:52 | 显示全部楼层
thanks
发表于 2024-10-22 09:55:33 | 显示全部楼层
哥,我这边下载下来的内容全是乱码。请问是哪一步有问题吗?看不到代码
发表于 2024-10-22 10:12:10 | 显示全部楼层
哥,你这个有些是乱码吧?
GMT+8, 2025-12-21 04:08 , Processed in 0.021206 second(s), 5 queries , Gzip On, Redis On.
