楼主: dc33912345
[求助] 请问cell name修改不了,应该如何解决?
发表于 2023-8-1 17:52:15 | 显示全部楼层
this is a standard protection in pdk from tsmс, if you insert nmos and then change it to pmos in circuit, cadence internal functions(callbacks) not update pcell parameters correctly,  to avoid this, PDK group blocks replacement of inserted instance in circuit.
you can fix it but I don't recommend it)))
发表于 2023-8-1 17:56:08 | 显示全部楼层
replacement can usually be done via skill script, if you don't have write permissions for PDK.
for nch ->nch_mac  you can use CIW->TSMC->update...(I don't remember  name of this function, try to find)
 楼主| 发表于 2023-8-1 19:15:13 | 显示全部楼层
光非 发表于 2023-8-1 17:32
nch 不是cellname嘛,怎么还选的instance name
感谢感谢!我太粗心了
 楼主| 发表于 2023-8-1 19:18:10 | 显示全部楼层
for n ...
thx! i have solved the problem!
发表于 2025-7-23 11:11:42 | 显示全部楼层
你好,请问这个问题是怎么解决的?我也遇到类似的问题了,tsmc的0.25工艺。谢谢。
GMT+8, 2025-12-23 11:52 , Processed in 0.016582 second(s), 3 queries , Gzip On, Redis On.
