查看: 2220|回复: 5
[求助] SMIC 12nm Warning&Error: Illegal placement
发表于 2023-8-1 10:25:07 | 显示全部楼层 |阅读模式
使用S12提供的脚本设置follow pin和stripe,在place阶段出现如下warning,并且warning太多最后成为error,density不高,是59.71%
 楼主| 发表于 2023-8-1 10:26:33 | 显示全部楼层
**WARN: (IMPSP-2042):        Disabling design rule check for instance 'L2/l2_tanh/mult_40_I2/U1600' ( cell: "AD1V0P5_90S9T16R" ). This instance may have illegal placement.  **WARN: (IMPSP-2042):        Disabling design rule check for instance 'L2/l2_tanh/mult_40/U1796' ( cell: "AD1V3_90S9T16R" ). This instance may have illegal placement.  **WARN: (IMPSP-2042):        Disabling design rule check for instance 'L1/l1_tanh/mult_40_I2/U1773' ( cell: "AD1V3_90S9T16R" ). This instance may have illegal placement.
 楼主| 发表于 2023-8-1 10:27:26 | 显示全部楼层
ERROR     IMPSP-2021           6  Could not legalize <%d> instances in the...
发表于 2023-9-5 15:36:41 | 显示全部楼层
同样遇到了这个问题,蹲大佬解答
发表于 2024-1-5 16:01:11 | 显示全部楼层
库是谁家提供的???
发表于 2024-1-9 15:47:00 | 显示全部楼层
检查一下row以及follow pin的电源与地有没有打反呢?
GMT+8, 2025-12-23 05:35 , Processed in 0.017696 second(s), 5 queries , Gzip On, Redis On.
