查看: 2333|回复: 8
[求助] IO perc 跑出来有LUP.1.0.1U,LUP.2.0.1U,LUP9U
发表于 2023-6-22 21:30:58 | 显示全部楼层 |阅读模式
IO perc 跑出来有LUP.1.0.1U,LUP.2.0.1U,LUP9U 的drc,
t12的工艺,IO是它自带的。它的意思是说N+或P+ guang ring 没接地或者VDD。我就奇怪,我已经在bump上定义了VDD,VSS,VDDPST,VSSPST这些,理论上来说VDD,VSS和这些gurad ring已经自动连起来了啊,怎么还报这些错。
发表于 2023-6-23 03:50:13 | 显示全部楼层
these errors appear when you define power and ground port names in DRC setup.
 楼主| 发表于 2023-6-23 18:32:57 | 显示全部楼层
我觉得应该不是这个问题,我已经设置正确了
发表于 2023-6-23 20:51:56 | 显示全部楼层
IO, typically, has multiple ports with same name, not all structures has connections by metals (breaks according to tools), all structures will be connected in full ring IO+power PADs. For clear DRC you need to connect all ports by RING PADs or by metals.
 楼主| 发表于 2023-6-25 18:24:37 | 显示全部楼层
LoktikVJ 发表于 2023-6-23 20:51
IO, typically, has multiple ports with same name, not all structures has connections by metals (brea ...
所有的最高层的port 跟AP相交的地方都打上了RV,但是结果还是一样
发表于 2023-9-29 19:59:48 | 显示全部楼层
perc本质上还是基于网表在做检查,power/ground是从网表中提取的,怀疑很大程度上和lvs connection rule有关系
发表于 2024-5-28 17:57:20 | 显示全部楼层
感谢
发表于 2024-12-1 00:16:34 | 显示全部楼层
请问找到原因了?我跑的也有,也是标准io。是不是guard-ring接的io内部power
发表于 2024-12-4 09:06:05 | 显示全部楼层
感谢,我也是想要的
GMT+8, 2025-12-14 21:15 , Processed in 0.022461 second(s), 5 queries , Gzip On, Redis On.
