查看: 2727|回复: 1
[求助] 使用AMS进行后防遇到的问题
发表于 2023-6-9 15:40:13 | 显示全部楼层 |阅读模式
我画了模拟顶层的版图,然后生成一个calibre view 后添加到config的switch view里面,为什么会报找不到器件的错啊?
ncelab: *E,CUVMUR (./netlist.vams,397|6): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_MP4' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
I34_MP3 (I34_MP3_d, I34_MP3_g, I34_MP3_s, I34_MP3_b);
ncelab: *E,CUVMUR (./netlist.vams,403|6): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_MP3' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
I34_I3_MMP5 (I34_I3_MMP5_d, I34_I3_MMP5_g, I34_I3_MMP5_s, I34_I3_MMP5_b
ncelab: *E,CUVMUR (./netlist.vams,409|10): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_I3_MMP5' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
I34_I3_MMP7 (I34_I3_MMP7_d, I34_I3_MMP7_g, I34_I3_MMP7_s, I34_I3_MMP7_b
ncelab: *E,CUVMUR (./netlist.vams,416|10): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_I3_MMP7' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
I34_I3_MMP6 (I34_I3_MMP6_d, I34_I3_MMP6_g, I34_I3_MMP6_s, I34_I3_MMP6_b
ncelab: *E,CUVMUR (./netlist.vams,423|10): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_I3_MMP6' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
I34_I3_MMP0 (I34_I3_MMP0_d, I34_I3_MMP0_g, I34_I3_MMP0_s, I34_I3_MMP0_b
ncelab: *E,CUVMUR (./netlist.vams,430|10): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_I3_MMP0' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
I34_I3_MMP2 (I34_I3_MMP2_d, I34_I3_MMP2_g, I34_I3_MMP2_s, I34_I3_MMP2_b
ncelab: *E,CUVMUR (./netlist.vams,437|10): instance 'tdc_final_test_post.I0@TDC_dif<module>.I34_I3_MMP2' of design unit 'pmos_1p8' is unresolved in 'worklib.TDC_dif:vams'.
发表于 2025-1-7 19:00:39 | 显示全部楼层
问题解决了吗
GMT+8, 2025-12-26 21:57 , Processed in 0.013658 second(s), 5 queries , Gzip On, Redis On.
