查看: 9894|回复: 38
[资料] c家数字DDI22.12
发表于 2023-5-26 11:33:25 | 显示全部楼层 |阅读模式
update :
链接: https://pan.baidu.com/s/1BXKsjRD_R3C35ZyyewmvPQ 提取码: p8tm 复制这段内容后打开百度网盘手机App,操作更方便哦
一个月有效。
Digital Design Implementation (DDI) System (TM) Release Version 22.1
DDI22.12-s080_1
Copyright 2022 Cadence Design Systems, Inc.
Products in DDI 22.1
Product        Executable        Version
INNOVUS        innovus           22.12-s080_1
GENUS          genus             22.12-s082_1
JOULES         joules            22.12-s053_1
The detailed DDI221 product family is shown in the table below.
Product        Description
3002           Virtuoso Digital Implementation
3003           Virtuoso Digital Implementation XL
3004           VDI-XL Block Capacity Option
CRBS100        Cerebrus Run Manager
CRBS110        Cerebrus Genus Option
CRBS120        Cerebrus Innovus Option
CRBS130        Cerebrus Tempus Option
CRBS140        Cerebrus Joules Option
DIGA100        Digital Analytics Platform Streaming
DIGA200        Digital Analytics Platform Applications
EDS10          Encounter Low Power GXL Option
EDS210         Encounter Clock Concurrent Optimization
EDS30          Encounter Advanced Node GXL Option
FE100GPS       First Encounter - XL
FE80           First Encounter - L
GEN100         Genus Synthesis Solution
GEN30          Genus Low Power Option
GEN40          Genus Physical Option
GEN80          Genus CPU Accelerator Option
INTG100        Integrity 3D-IC
INVS03         Innovus 3nm Option
INVS05         Innovus 5nm Option
INVS07         Innovus 7nm Option
INVS10         Innovus 10nm Option
INVS100        Innovus Implementation System
INVS20         Innovus 20/16/14nm Option
INVS25         Innovus Superconducting Option
INVS30         Innovus Mixed Signal Option
INVS35         Innovus High Frequency Route Option
INVS40         Innovus Hierarchical Design Option
INVS45         Innovus GigaPlace - XL Option
INVS46         Innovus Early Hierarchical Floorplan Synthesis Option
INVS48         Innovus GigaPlace-GXL Option
INVS55         Innovus Power Integrity Option
INVS56         Innovus Automotive Flow Option
INVS60         Innovus 3D-IC Option
INVS65         Innovus Machine Learning Implementation Option
INVS66         Innovus Machine Learning Training Option
INVS80         Innovus CPU Accelerator Option
INVS85         Innovus Distributed Option
INVS95         Innovus Implementation System - Basic
INVSI10        Innovus I10nm Option
INVSI20        Innovus I20nm Option
JLS100         Joules RTL Power Solution
JLS20          Joules Implementation Option
JLS200         Joules Power Solution XL
JLS80          Joules Multihost Option
Executables from other streams compatible with DDI System 22.1
Product           Executable           Stream/Version
TEMPUS              tempus             22.12
VOLTUS              voltus             22.12
VIRTUOSO            virtuoso           6.1.8
CEREBRUS            cerebrus           22.1
QUANTUS             qrc                21.2.2-s138
补充内容 (2023-11-18 01:14):
链接:https://pan.baidu.com/s/1vgClUYYCmeQMV7JDnO2mfg?pwd=yrs3
提取码:yrs3
补充内容 (2024-3-15 00:08):
请搜DDI23~~~
DDI22.12.txt
75 Bytes, 下载次数: 253 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2023-5-26 20:19:40 | 显示全部楼层
多谢分享
发表于 2023-5-26 21:50:05 | 显示全部楼层
ksadnksand
发表于 2023-5-26 22:05:44 | 显示全部楼层
Thank you very much.
发表于 2023-8-2 11:49:47 | 显示全部楼层
过期了,可以再分享吗?
 楼主| 发表于 2023-8-3 01:03:36 | 显示全部楼层
更新了,见主贴,一个月有效。
发表于 2023-8-10 15:27:44 | 显示全部楼层
多谢!可否将md5sum文件一并上传?baidu下载太容易出错了
发表于 2023-8-30 10:09:25 | 显示全部楼层
请问这个  环境变量怎么设置呢
发表于 2023-9-12 16:37:56 | 显示全部楼层
失效了,可以再发一下吗,谢谢
发表于 2023-9-28 13:17:56 来自手机 | 显示全部楼层
过期了可以再分享一下吗
GMT+8, 2025-9-19 05:44 , Processed in 0.020760 second(s), 4 queries , Gzip On, Redis On.
