查看: 3721|回复: 11
[求助] 最近逛了论坛发现GM/ID设计方法,可以用来设计电路但是实际上看到的大多数仅仅是用来
发表于 2023-5-18 22:26:04 | 显示全部楼层 |阅读模式
如果想做LDO,BG等一些大工程还能用这个方法吗?有一个在公司做设计的大佬说这种方法就是搞搞学术用的,实际上大家做项目都是经验值直接调,目前还是小白也不懂怎么给经验值,怎么办呢?有过来人给指导指导吗?
发表于 2023-5-19 08:55:24 | 显示全部楼层
在这本书中,作者提供使用gm/Id sizing好些电路的例子
[1] P. G. A. Jespers and B. Murmann, Systematic Design of Analog CMOS Circuits: Using Pre-Computed Lookup Tables. Cambridge: Cambridge University Press, 2017. Accessed: Oct. 31, 2017.
Practical Circuit Examples
5.1 Constant Transconductance Bias Circuit
5.2 High-Swing Cascoded Current Mirror 171
5.3 Low-Dropout Voltage Regulator 177
5.4 RF Low-Noise Ampliier 189
5.5 Sizing the LNA for Minimum HD2 197
5.5 Charge Ampliier 200
5.6 Designing for Process Corners
Practical Circuit Examples II
6.1 Basic OTA for Switched-Capacitor Circuits 226
6.2 Folded-Cascode OTA for Switched-Capacitor Circuits 249
6.3 Two-Stage OTA for Switched-Capacitor Circuits 267
6.4 Simpliied Design Flows 283
6.5 Sizing Switches
在这两篇文章中,作者用gm/Id方法设计了BG;
[1]
H. Omran, M. H. Amer, and A. M. Mansour, ‘Systematic Design of Bandgap Voltage Reference Using Precomputed Lookup Tables’, IEEE Access, vol. 7, pp. 100131–100142, 2019
Despite the inherent finite accuracy of the LUT-based design approach, we demonstrate that a precision bandgap circuit can be designed with less than 1-ppm error.
[2] A. A. Youssef, B. Murmann, and H. Omran, ‘Analog IC Design Using Precomputed Lookup Tables: Challenges and Solutions’, IEEE Access, vol. 8, pp. 134640–134652, 2020, doi: 10.1109/ACCESS.2020.3010875.
We evaluate the efficacy of the proposed methods using two classical analog circuits, a bandgap reference and a folded cascode amplifier. In the bandgap example, we observe less than 1 ppm error between the LUT-predicted temperature coefficient and circuit simulation.
个人觉得该方法潜力很大,但第一次上手需要不少时间,学习曲线相对传统方法更陡峭一些。
回复 支持 2 反对 0
发表于 2023-5-19 09:11:10 | 显示全部楼层
我来补一下资料
Systematic Design of Analog CMOS Circuits.pdf
23.59 MB, 下载次数: 106 , 下载积分: 资产 -7 信元, 下载支出 7 信元
回复 支持 0 反对 0
发表于 2023-5-19 14:22:47 | 显示全部楼层
kan e kan
发表于 2023-5-23 11:35:02 | 显示全部楼层
事实就是gm/id基本就是用来发文章,别跟我说你做项目真的用gm/id查找表。
 楼主| 发表于 2023-5-23 12:41:51 | 显示全部楼层
嗷嗷是这样,那做项目的话都是手算和经验值是嘛
发表于 2023-5-23 18:53:32 | 显示全部楼层
对,两个足够了
发表于 2023-6-22 21:57:13 | 显示全部楼层
谢谢分享
发表于 2023-7-7 16:46:56 | 显示全部楼层
学习学习
发表于 2024-10-12 11:34:07 | 显示全部楼层
THANKS.
GMT+8, 2025-12-22 20:51 , Processed in 0.020805 second(s), 4 queries , Gzip On, Redis On.
