查看: 4431|回复: 2
[求助] QRC错误
发表于 2023-5-14 23:53:23 | 显示全部楼层 |阅读模式
跑QRC跑不通,但lvs和drc都能正常通过,请问如何解决
  Cadence Quantus QRC Extraction - 64-bit Parasitic Extractor - Version
15.1.0-p101 Thu Jun 11 23:12:18 PDT 2015
                                    Copyright 2015 Cadence Design Systems,
Inc.
INFO (LBRCXM-624): No temperature processing will occur for the layer MIM, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer pdfCont, because thislayer has no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer ndfCont, because thislayer has no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer polyCont, because thislayer has no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer via1, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer via2, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer via3a, because thislayer has no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer via3c, because thislayer has no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer via4, because this layerhas no Tc1 and Tc2.
INFO (LBRCXM-624): No temperature processing will occur for the layer via5, because this layerhas no Tc1 and Tc2.
INFO (LBRCXU-108): Starting
/opt/cadence/IC617/bin/qrcToDfII -extract both -run_name Design -cdlout_run_dir /NICIEC2023/lvs_test/boost_lower -check_cell_view FALSE -device_finger_delimiter @ -extracted_view av_extracted_1 -lvs_source hcci -cap_models no -capacitor pcapacitor -res_models no -resistor presistor -cap_prop_name c -res_prop_name r -t -extview_tmp /tmp/qrc_202144/Design/extview.tmp -run_dir /tmp/qrc_202144/Design -lib_name Test -cell_name boost_lower -view_name layout -extview_rul /NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/extview.rul -server /opt/cadence/EXT151/tools.lnx86/extraction/bin/64bit//../shapeServer
WARNING (LBRCXU-172): m2write fd 10, 1 tries, bytes -1 of 14, errno 9 Bad file descriptor
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.00s.
device n18 M ngate18 n18 ivpcell smic18bcdepi D G S B
Loading smic18bcdepi/libInit.il ...
        Loading smic18bcdepi/loadCxt.ile ... done!
        Loading context 'smic18bcdepi' from library 'smic18bcdepi' ... done!
        Loading context 'pdkUtils' from library 'smic18bcdepi' ... done!
        Loading smic18bcdepi/libInitCktPro.il ... done!
        Loading smic18bcdepi/libInitCustomExit.il ... Loading libInitCustomExit.il for smic18bcdepi
done!
Loaded smic18bcdepi/libInit.il successfully!
Loading smic skill utility
file="batchSetCDF.ile"loadfile="/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/smic18bcdepi/../SMIC18_skillUtility/batchSetCDF.ile"/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/smic18bcdepi/../SMIC18_skillUtility/batchSetCDF.ile
*Error* eval: undefined function - ciwMenuInit
*Error* load: error while loading file - "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/smic18bcdepi/../SMIC18_skillUtility/batchSetCDF.ile" at line 9
device n18_ckt X ngate18_ckt n18_ckt ivpcell smic18bcdepi D G S B
device nnt18 M nntgate18 nnt18 ivpcell smic18bcdepi D G S B
device nnt18_ckt X nntgate18_ckt nnt18_ckt ivpcell smic18bcdepi D G S B
device n50 M ngate50 n50 ivpcell smic18bcdepi D G S B
device nnt50 M nntgate50 nnt50 ivpcell smic18bcdepi D G S B
device nnt50_ckt X nntgate50_ckt nnt50_ckt ivpcell smic18bcdepi D G S B
device n50_ckt X ngate50_ckt n50_ckt ivpcell smic18bcdepi D G S B
device p18 M pgate18 p18 ivpcell smic18bcdepi D G S B
device p18_ckt X pgate18_ckt p18_ckt ivpcell smic18bcdepi D G S B
device p50 M pgate50 p50 ivpcell smic18bcdepi D G S B
device p50_ckt X pgate50_ckt p50_ckt ivpcell smic18bcdepi D G S B
device n18_dnw_ckt X ngate18dnw_ckt n18_dnw_ckt ivpcell smic18bcdepi D G S B T B2
device n50_dnw_ckt X ngate50dnw_ckt n50_dnw_ckt ivpcell smic18bcdepi D G S B T B2
device p18_dnw_ckt X pgate18dnw_ckt p18_dnw_ckt ivpcell smic18bcdepi D G S B B2
device p50_dnw_ckt X pgate50dnw_ckt p50_dnw_ckt ivpcell smic18bcdepi D G S B B2
device n18_dnw_4t_ckt X ngate18dnw_4t_ckt n18_dnw_4t_ckt ivpcell smic18bcdepi D G S B
device n50_dnw_4t_ckt X ngate50dnw_4t_ckt n50_dnw_4t_ckt ivpcell smic18bcdepi D G S B
device p18_dnw_4t_ckt X pgate18dnw_4t_ckt p18_dnw_4t_ckt ivpcell smic18bcdepi D G S B
device p50_dnw_4t_ckt X pgate50dnw_4t_ckt p50_dnw_4t_ckt ivpcell smic18bcdepi D G S B
device nld10f_ckt X ngate100_ckt nld10f_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device nld12f_ckt X ngate120_ckt nld12f_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld10f_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld20f_ckt X ngate200_ckt nld20f_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld12f_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld35_ckt X ngate350_no_hvbn_ckt nld35_ckt ivpcell smic18bcdepi D G S PEPI NWHT
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld20f_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld35h_ckt X ngate350_ckt nld35h_ckt ivpcell smic18bcdepi D G S PEPI SUB
device nld40h_ckt X ngate400_ckt nld40h_ckt ivpcell smic18bcdepi D G S PEPI SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld35h_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld10_ckt X pgate100_ckt pld10_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld40h_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld12_ckt X pgate120_ckt pld12_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld10_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld20_ckt X pgate200_ckt pld20_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld12_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld35_ckt X pgate350_ckt pld35_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld20_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld40_ckt X pgate400_ckt pld40_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld35_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld12g5frx_ckt X ngate120_ckt_rx nld12g5frx_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld40_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld20g5frx_ckt X ngate200_ckt_rx nld20g5frx_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld12g5frx_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld5g5h_ckt X nldgate5g5h_ckt nld5g5h_ckt ivpcell smic18bcdepi D G S B T B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld20g5frx_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld5g5_ckt X nldgate5g5_ckt nld5g5_ckt ivpcell smic18bcdepi D G S B
device nld4g5h_ckt X nldgate4g5h_ckt nld4g5h_ckt ivpcell smic18bcdepi D G S B T B2
device nld4g5_ckt X nldgate4g5_ckt nld4g5_ckt ivpcell smic18bcdepi D G S B
device pld5g5_ckt X pldgate5g5_ckt pld5g5_ckt ivpcell smic18bcdepi D G S B B2
device pld4g5_ckt X pldgate4g5_ckt pld4g5_ckt ivpcell smic18bcdepi D G S B B2
device nld10_wohvbn_ckt X ngate100_wohvbn_ckt nld10_wohvbn_ckt ivpcell smic18bcdepi D G S PEPI NWHT
device nld20_wohvbn_ckt X ngate200_wohvbn_ckt nld20_wohvbn_ckt ivpcell smic18bcdepi D G S PEPI NWHT
device nld40_wohvbn_ckt X ngate400_wohvbn_ckt nld40_wohvbn_ckt ivpcell smic18bcdepi D G S PEPI NWHT
device pld10_wohvbn_ckt X pgate100_wohvbn_ckt pld10_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
device pld20_wohvbn_ckt X pgate200_wohvbn_ckt pld20_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
device pld35_wohvbn_ckt X pgate350_wohvbn_ckt pld35_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
device pld40_wohvbn_ckt X pgate400_wohvbn_ckt pld40_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
device nld5g5h_hvbn_ckt X nldgate5g5h_hvbn_ckt nld5g5h_hvbn_ckt ivpcell smic18bcdepi D G S B HVBN SUB
device nld5g5_hvbn_ckt X nldgate5g5_hvbn_ckt nld5g5_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld5g5h_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld5g5_hvbn_ckt X pldgate5g5_hvbn_ckt pld5g5_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld5g5_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld4g5h_hvbn_ckt X nldgate4g5h_hvbn_ckt nld4g5h_hvbn_ckt ivpcell smic18bcdepi D G S B HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld5g5_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld4g5_hvbn_ckt X nldgate4g5_hvbn_ckt nld4g5_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld4g5h_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld4g5_hvbn_ckt X pldgate4g5_hvbn_ckt pld4g5_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld4g5_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld12g5frx_wohvbn_ckt X ngate120_ckt_rx_wohvbn nld12g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S PEPI NWHT
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld4g5_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld20g5frx_wohvbn_ckt X ngate200_ckt_rx_wohvbn nld20g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S PEPI NWHT
device nld12g5h_ckt X nldgate12g5h_ckt nld12g5h_ckt ivpcell smic18bcdepi D G S B B2
device nld12g5_ckt X nldgate12g5_ckt nld12g5_ckt ivpcell smic18bcdepi D G S B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld12g5h_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld12g5_ckt X pldgate12g5_ckt pld12g5_ckt ivpcell smic18bcdepi D G S B B2
device nld5ga_wohvbn_ckt X nldgate5ga_wohvbn_ckt nld5ga_wohvbn_ckt ivpcell smic18bcdepi D G S B T B2
device nld5ga_hvbn_ckt X nldgate5ga_hvbn_ckt nld5ga_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device pld5ga_wohvbn_ckt X pldgate5ga_wohvbn_ckt pld5ga_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld5ga_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld5ga_hvbn_ckt X pldgate5ga_hvbn_ckt pld5ga_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
device pld9_hvbn_ckt X pgate90_hvbn_ckt pld9_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld5ga_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld9_wohvbn_ckt X pgate90_wohvbn_ckt pld9_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld9_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld16_hvbn_ckt X pgate160_hvbn_ckt pld16_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld9_wohvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld16_wohvbn_ckt X pgate160_wohvbn_ckt pld16_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld16_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld24_hvbn_ckt X pgate240_hvbn_ckt pld24_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
device pld24_wohvbn_ckt X pgate240_wohvbn_ckt pld24_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld24_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pld28_hvbn_ckt X pgate280_hvbn_ckt pld28_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
device pld28_wohvbn_ckt X pgate280_wohvbn_ckt pld28_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pld28_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nde6g5_hvbn_ckt X nde6g5_hvbn_seed nde6g5_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device nde6g5_wohvbn_ckt X nde6g5_wohvbn_seed nde6g5_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nde6g5_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pde6g5_hvbn_ckt X pde6g5_hvbn_seed pde6g5_hvbn_ckt ivpcell smic18bcdepi D G S HVBN SUB
device pde6g5_wohvbn_ckt X pde6g5_wohvbn_seed pde6g5_wohvbn_ckt ivpcell smic18bcdepi D G S B B2
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (pde6g5_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld40g5frx_wohvbn_ckt X nld40g5frx_wohvbn_seed nld40g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
device nld36g5frx_wohvbn_ckt X nld36g5frx_wohvbn_seed nld36g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
device nld28g5frx_wohvbn_ckt X nld28g5frx_wohvbn_seed nld28g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
device nld28g5frx_hvbn_ckt X nld28g5frx_hvbn_seed nld28g5frx_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device nld24g5frx_wohvbn_ckt X nld24g5frx_wohvbn_seed nld24g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld28g5frx_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld24g5frx_hvbn_ckt X nld24g5frx_hvbn_seed nld24g5frx_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device nld16g5frx_wohvbn_ckt X nld16g5frx_wohvbn_seed nld16g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld24g5frx_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld16g5frx_hvbn_ckt X nld16g5frx_hvbn_seed nld16g5frx_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device nld9g5frx_wohvbn_ckt X nld9g5frx_wohvbn_seed nld9g5frx_wohvbn_ckt ivpcell smic18bcdepi D G S B NWHT SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld16g5frx_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device nld9g5frx_hvbn_ckt X nld9g5frx_hvbn_seed nld9g5frx_hvbn_ckt ivpcell smic18bcdepi D G S PEPI HVBN SUB
device pvar18_ckt X cn18vargt pvar18_ckt ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (nld9g5frx_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device pvar50_ckt X cn50vargt pvar50_ckt ivpcell smic18bcdepi PLUS MINUS
device pvar18_3t_ckt X cn18vargt_3t_wohvbn pvar18_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device pvar18_3t_ckt X cn18vargt_3t_hvbn pvar18_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device pvar50_3t_ckt X cn50vargt_3t_wohvbn pvar50_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device pvar50_3t_ckt X cn50vargt_3t_hvbn pvar50_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device ndio18 D ndio18 ndio18 ivpcell smic18bcdepi PLUS MINUS
device ndio50 D ndio50 ndio50 ivpcell smic18bcdepi PLUS MINUS
device nwdio D nwdio nwdio ivpcell smic18bcdepi PLUS MINUS
device n50npb D n50npb n50npb ivpcell smic18bcdepi PLUS MINUS
device pdio18 D pdio18 pdio18 ivpcell smic18bcdepi PLUS MINUS
device pdio50 D pdio50 pdio50 ivpcell smic18bcdepi PLUS MINUS
device diobpw D diobpw diobpw ivpcell smic18bcdepi PLUS MINUS
device pwdio50 D pwdio50 pwdio50 ivpcell smic18bcdepi PLUS MINUS
device dnwdio D dnwdio dnwdio ivpcell smic18bcdepi PLUS MINUS
device diownepihbn D diownepihbn diownepihbn ivpcell smic18bcdepi PLUS MINUS
device diowphnhbn D diowphnhbn diowphnhbn ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (diownepihbn ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device dioepihbn D dioepihbn dioepihbn ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (diowphnhbn ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device dzener55w7l7_hvbn_ckt X dzener55w7l7_hvbn dzener55w7l7_hvbn_ckt ivpcell smic18bcdepi PLUS MINUS HVBN PSUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (dioepihbn ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device dzener65w3l3_hvbn_ckt X dzener65w3l3_hvbn dzener65w3l3_hvbn_ckt ivpcell smic18bcdepi PLUS MINUS HVBN PSUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (dzener55w7l7_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device dzener55w7l7_wohvbn_ckt X dzener55w7l7_wohvbn dzener55w7l7_wohvbn_ckt ivpcell smic18bcdepi PLUS MINUS NWHT PSUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (dzener65w3l3_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device dzener65w3l3_wohvbn_ckt X dzener65w3l3_wohvbn dzener65w3l3_wohvbn_ckt ivpcell smic18bcdepi PLUS MINUS NWHT PSUB
device sdmte20_hvbn_ckt X sdmte20_hvbn sdmte20_hvbn_ckt ivpcell smic18bcdepi PLUS MINUS B
device sdmte30_hvbn_ckt X sdmte30_hvbn sdmte30_hvbn_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (sdmte20_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device sdmte20_wohvbn_ckt X sdmte20_wohvbn sdmte20_wohvbn_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (sdmte30_hvbn_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device sdmte30_wohvbn_ckt X sdmte30_wohvbn sdmte30_wohvbn_ckt ivpcell smic18bcdepi PLUS MINUS B
device parasitic_nwdio D parasitic_nwdio parasitic_nwdio ivpcell smic18bcdepi PLUS MINUS
device parasitic_diobpw D parasitic_diobpw parasitic_diobpw ivpcell smic18bcdepi PLUS MINUS
device parasitic_diobpw D parasitic_wpnwht parasitic_diobpw ivpcell smic18bcdepi PLUS MINUS
device parasitic_dnwdio D parasitic_dnwdio parasitic_dnwdio ivpcell smic18bcdepi PLUS MINUS
device parasitic_dnwdio D parasitic_nwhtdio parasitic_dnwdio ivpcell smic18bcdepi PLUS MINUS
device parasitic_dnwdio D parasitic_sdnwdio parasitic_dnwdio ivpcell smic18bcdepi PLUS MINUS
device parasitic_dnwdio D parasitic_znwhtdio parasitic_dnwdio ivpcell smic18bcdepi PLUS MINUS
device parasitic_dioepihbn D parasitic_dioepihbn_nwht parasitic_dioepihbn ivpcell smic18bcdepi PLUS MINUS
device parasitic_dioepihbn D parasitic_dioepihbn_dnw parasitic_dioepihbn ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (parasitic_dioepihbn ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device parasitic_diohnpb D parasitic_diohnpb_nwht parasitic_diohnpb ivpcell smic18bcdepi PLUS MINUS
device parasitic_diohnpb D parasitic_diohnpb_dnw parasitic_diohnpb ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (parasitic_diohnpb ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device parasitic_diohnpb D parasitic_diohnpb_sdnw parasitic_diohnpb ivpcell smic18bcdepi PLUS MINUS
device rpdif_ckt X res_rpdif_ckt rpdif_ckt ivpcell smic18bcdepi PLUS MINUS B
device rndif_ckt X res_rndif_ckt rndif_ckt ivpcell smic18bcdepi PLUS MINUS B
device rppo_ckt X res_rppo_ckt rppo_ckt ivpcell smic18bcdepi PLUS MINUS
device rppo_3t_ckt X res_rppo_3t_ckt_nw rppo_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rppo_3t_ckt X res_rppo_3t_ckt_pw rppo_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rnpo_ckt X res_rnpo_ckt rnpo_ckt ivpcell smic18bcdepi PLUS MINUS
device rnpo_3t_ckt X res_rnpo_3t_ckt_pw rnpo_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rnpo_3t_ckt X res_rnpo_3t_ckt_nw rnpo_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rpdifsab_ckt X res_rpdifsab_ckt rpdifsab_ckt ivpcell smic18bcdepi PLUS MINUS B
device rndifsab_ckt X res_rndifsab_ckt rndifsab_ckt ivpcell smic18bcdepi PLUS MINUS B
device rpposab_ckt X res_rpposab_ckt rpposab_ckt ivpcell smic18bcdepi PLUS MINUS
device rpposab_3t_ckt X res_rpposab_3t_ckt_nw rpposab_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rpposab_3t_ckt X res_rpposab_3t_ckt_pw rpposab_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rnposab_ckt X res_rnposab_ckt rnposab_ckt ivpcell smic18bcdepi PLUS MINUS
device rnposab_3t_ckt X res_rnposab_3t_ckt_pw rnposab_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rnposab_3t_ckt X res_rnposab_3t_ckt_nw rnposab_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rhrpo_ckt X res_rhrpo_ckt rhrpo_ckt ivpcell smic18bcdepi PLUS MINUS
device rhrpo_3t_ckt X res_rhrpo_3t_ckt_nw rhrpo_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrpo_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rhrpo_3t_ckt X res_rhrpo_3t_ckt_pw rhrpo_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrpo_3t_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rhrp_hv_ckt X res_rhrp_hv_ckt rhrp_hv_ckt ivpcell smic18bcdepi PLUS MINUS
device rhrp_hv_3t_ckt X res_rhrp_hv_3t_ckt rhrp_hv_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrp_hv_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rhrp_3k_ckt X res_rhrpo_ckt rhrp_3k_ckt ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrp_hv_3t_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rhrp_3k_3t_ckt X res_rhrpo_3t_ckt_nw rhrp_3k_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rhrp_3k_3t_ckt X res_rhrpo_3t_ckt_pw rhrp_3k_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
device rhrp_hv_3k_ckt X res_rhrp_hv_ckt rhrp_hv_3k_ckt ivpcell smic18bcdepi PLUS MINUS
device rhrp_hv_3k_3t_ckt X res_rhrp_hv_3t_ckt rhrp_hv_3k_3t_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrp_hv_3k_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rnwaa_ckt X res_rnwaa_ckt rnwaa_ckt ivpcell smic18bcdepi PLUS MINUS B
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrp_hv_3k_3t_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rnwsti_ckt X res_rnwsti_ckt rnwsti_ckt ivpcell smic18bcdepi PLUS MINUS B
device rnwaa5v_ckt X res_rnwaa5v_ckt rnwaa5v_ckt ivpcell smic18bcdepi PLUS MINUS B
device rnwsti5v_ckt X res_rnwsti5v_ckt rnwsti5v_ckt ivpcell smic18bcdepi PLUS MINUS B
device rpdif R res_rpdif rpdif ivpcell smic18bcdepi PLUS MINUS
device rndif R res_rndif rndif ivpcell smic18bcdepi PLUS MINUS
device rppo R res_rppo rppo ivpcell smic18bcdepi PLUS MINUS
device rppo_3t R res_rppo_3t rppo_3t ivpcell smic18bcdepi PLUS MINUS
device rnpo R res_rnpo rnpo ivpcell smic18bcdepi PLUS MINUS
device rnpo_3t R res_rnpo_3t rnpo_3t ivpcell smic18bcdepi PLUS MINUS
device rpdifsab R res_rpdifsab rpdifsab ivpcell smic18bcdepi PLUS MINUS
device rndifsab R res_rndifsab rndifsab ivpcell smic18bcdepi PLUS MINUS
device rpposab R res_rpposab rpposab ivpcell smic18bcdepi PLUS MINUS
device rpposab_3t R res_rpposab_3t rpposab_3t ivpcell smic18bcdepi PLUS MINUS
device rnposab R res_rnposab rnposab ivpcell smic18bcdepi PLUS MINUS
device rnposab_3t R res_rnposab_3t rnposab_3t ivpcell smic18bcdepi PLUS MINUS
device rhrpo R res_rhrpo rhrpo ivpcell smic18bcdepi PLUS MINUS
device rhrpo_3t R res_rhrpo_3t rhrpo_3t ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrpo ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rhrp_3k R res_rhrpo rhrp_3k ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rhrpo_3t ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rhrp_3k_3t R res_rhrpo_3t rhrp_3k_3t ivpcell smic18bcdepi PLUS MINUS
device rnwaa R res_rnwaa rnwaa ivpcell smic18bcdepi PLUS MINUS
device rnwsti R res_rnwsti rnwsti ivpcell smic18bcdepi PLUS MINUS
device rnwaa5v R res_rnwaa5v rnwaa5v ivpcell smic18bcdepi PLUS MINUS
device rnwsti5v R res_rnwsti5v rnwsti5v ivpcell smic18bcdepi PLUS MINUS
device rm1 R rm1 rm1 ivpcell smic18bcdepi PLUS MINUS
device rm2 R rm2 rm2 ivpcell smic18bcdepi PLUS MINUS
device rm3 R rm3 rm3 ivpcell smic18bcdepi PLUS MINUS
device rm4 R rm4 rm4 ivpcell smic18bcdepi PLUS MINUS
device rm5 R rm5 rm5 ivpcell smic18bcdepi PLUS MINUS
device rtm_thick R rm6 rtm_thick ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rm5 ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rtm_thick R rm5 rtm_thick ivpcell smic18bcdepi PLUS MINUS
device rtm_thick R rm4 rtm_thick ivpcell smic18bcdepi PLUS MINUS
device rtm_thick R rm3 rtm_thick ivpcell smic18bcdepi PLUS MINUS
device rtm_thin R rm6 rtm_thin ivpcell smic18bcdepi PLUS MINUS
device rtm_thin R rm5 rtm_thin ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rtm_thin ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rtm_thin R rm4 rtm_thin ivpcell smic18bcdepi PLUS MINUS
device rtm_thin R rm3 rtm_thin ivpcell smic18bcdepi PLUS MINUS
device rmtt2 R rm3 rmtt2 ivpcell smic18bcdepi PLUS MINUS
device rmtt2 R rm4 rmtt2 ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (rmtt2 ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device rmtt2 R rm5 rmtt2 ivpcell smic18bcdepi PLUS MINUS
device rmtt2 R rm6 rmtt2 ivpcell smic18bcdepi PLUS MINUS
device rmt1 R rm3 rmt1 ivpcell smic18bcdepi PLUS MINUS
device rmt1 R rm4 rmt1 ivpcell smic18bcdepi PLUS MINUS
device rmt1 R rm5 rmt1 ivpcell smic18bcdepi PLUS MINUS
device rmt1 R rm6 rmt1 ivpcell smic18bcdepi PLUS MINUS
device mim_ckt X mimcap mim_ckt ivpcell smic18bcdepi PLUS MINUS
device mim_ckt X mimcap_m4m5 mim_ckt ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (mim_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device mim_ckt X mimcap_m3m4 mim_ckt ivpcell smic18bcdepi PLUS MINUS
device mim_ckt X mimcap_m2m3 mim_ckt ivpcell smic18bcdepi PLUS MINUS
device mim_typ2_ckt X mimcap_m2m3 mim_typ2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim_typ2_ckt X mimcap_m3m4 mim_typ2_ckt ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (mim_typ2_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device mim_typ2_ckt X mimcap_m4m5 mim_typ2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim2_ckt X mimcap mim2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim2_ckt X mimcap_m2m3 mim2_ckt ivpcell smic18bcdepi PLUS MINUS
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (mim2_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device mim2_ckt X mimcap_m3m4 mim2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim2_ckt X mimcap_m4m5 mim2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim2_typ2_ckt X mimcap_m2m3 mim2_typ2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim2_typ2_ckt X mimcap_m3m4 mim2_typ2_ckt ivpcell smic18bcdepi PLUS MINUS
device mim2_typ2_ckt X mimcap_m4m5 mim2_typ2_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom12 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom13 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom14 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom15 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom23 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom24 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom25 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom34 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom35 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device mom_ckt X mom45 mom_ckt ivpcell smic18bcdepi PLUS MINUS
device pnp50nwdnwa4 Q pnpemit50nwdnwa4 pnp50nwdnw ivpcell smic18bcdepi C B E
device pnp50nwdnwa25 Q pnpemit50nwdnwa25 pnp50nwdnw ivpcell smic18bcdepi C B E
device pnp50nwdnwa100 Q pnpemit50nwdnwa100 pnp50nwdnw ivpcell smic18bcdepi C B E
device pnp18a4 Q pnpemit18a4 pnp18 ivpcell smic18bcdepi C B E
device pnp18a25 Q pnpemit18a25 pnp18 ivpcell smic18bcdepi C B E
device pnp18a100 Q pnpemit18a100 pnp18 ivpcell smic18bcdepi C B E
device pnp50nwa4 Q pnpemit50nwa4 pnp50nw ivpcell smic18bcdepi C B E
device pnp50nwa25 Q pnpemit50nwa25 pnp50nw ivpcell smic18bcdepi C B E
device pnp50nwa100 Q pnpemit50nwa100 pnp50nw ivpcell smic18bcdepi C B E
device npn18a4 Q npnemit18a4 npn18 ivpcell smic18bcdepi C B E
device npn18a25 Q npnemit18a25 npn18 ivpcell smic18bcdepi C B E
device npn18a100 Q npnemit18a100 npn18 ivpcell smic18bcdepi C B E
device npn50a4 Q npnemit50a4 npn50 ivpcell smic18bcdepi C B E
device npn50a25 Q npnemit50a25 npn50 ivpcell smic18bcdepi C B E
device npn50a100 Q npnemit50a100 npn50 ivpcell smic18bcdepi C B E
device npnwnpepihbn4 Q npnwnpepihbna4 npnwnpepihbn ivpcell smic18bcdepi C B E
device npnwnpepihbn25 Q npnwnpepihbna25 npnwnpepihbn ivpcell smic18bcdepi C B E
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (npnwnpepihbn ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device npnwnpepihbn100 Q npnwnpepihbna100 npnwnpepihbn ivpcell smic18bcdepi C B E
device pnp50nwdnwa4_mis_ckt X pnpemit50nwdnwa4_ckt pnp50nwdnw_mis_ckt ivpcell smic18bcdepi C B E
device pnp50nwdnwa25_mis_ckt X pnpemit50nwdnwa25_ckt pnp50nwdnw_mis_ckt ivpcell smic18bcdepi C B E
device pnp50nwdnwa100_mis_ckt X pnpemit50nwdnwa100_ckt pnp50nwdnw_mis_ckt ivpcell smic18bcdepi C B E
device pnp18a4_mis_ckt X pnpemit18a4_ckt pnp18_mis_ckt ivpcell smic18bcdepi C B E
device pnp18a25_mis_ckt X pnpemit18a25_ckt pnp18_mis_ckt ivpcell smic18bcdepi C B E
device pnp18a100_mis_ckt X pnpemit18a100_ckt pnp18_mis_ckt ivpcell smic18bcdepi C B E
device pnp50nwa4_mis_ckt X pnpemit50nwa4_ckt pnp50nw_mis_ckt ivpcell smic18bcdepi C B E
device pnp50nwa25_mis_ckt X pnpemit50nwa25_ckt pnp50nw_mis_ckt ivpcell smic18bcdepi C B E
device pnp50nwa100_mis_ckt X pnpemit50nwa100_ckt pnp50nw_mis_ckt ivpcell smic18bcdepi C B E
device npn18a4_mis_ckt X npnemit18a4_ckt npn18_mis_ckt ivpcell smic18bcdepi C B E SUB
device npn18a25_mis_ckt X npnemit18a25_ckt npn18_mis_ckt ivpcell smic18bcdepi C B E SUB
device npn18a100_mis_ckt X npnemit18a100_ckt npn18_mis_ckt ivpcell smic18bcdepi C B E SUB
device npn50a4_mis_ckt X npnemit50a4_ckt npn50_mis_ckt ivpcell smic18bcdepi C B E SUB
device npn50a25_mis_ckt X npnemit50a25_ckt npn50_mis_ckt ivpcell smic18bcdepi C B E SUB
device npn50a100_mis_ckt X npnemit50a100_ckt npn50_mis_ckt ivpcell smic18bcdepi C B E SUB
device npnwnpepihbn4_mis_ckt X npnwnpepihbna4_ckt npnwnpepihbn_mis_ckt ivpcell smic18bcdepi C B E SUB
device npnwnpepihbn25_mis_ckt X npnwnpepihbna25_ckt npnwnpepihbn_mis_ckt ivpcell smic18bcdepi C B E SUB
*WARNING* (DB-270211): dbOpenCellViewByType: Failed to open cellview (npnwnpepihbn_mis_ckt ivpcell) from lib (smic18bcdepi) in 'r' mode because cellview does not exist, or cellview type is not recognized by dbOpenCellViewByType.
device npnwnpepihbn100_mis_ckt X npnwnpepihbna100_ckt npnwnpepihbn_mis_ckt ivpcell smic18bcdepi C B E SUB
All device symbols for the extracted view are present.
INFO (LBRCXU-114): Finished /opt/cadence/IC617/bin/qrcToDfII
INFO (LBRCXM-642): Constructing the RCX run script
WARNING (RCXSPIC-27104): p2lvsfile in tech directory does not have resistance
temperature coefficients (TC1, TC2). ?temperature is ignored
INFO (AGDPRP-31045): Checking /NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/extview.trp for pin name mapping
*WARNING* at "agdsPrep": No cellname matches entry "mim_typ2_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim2_typ2_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim2_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim_m2m3_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim2_m2m3_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim_m3m4_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "mim2_m3m4_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "pvar18_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "pvar50_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "pvar18_3t_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
*WARNING* at "agdsPrep": No cellname matches entry "pvar50_3t_ckt*" in file "/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt". Check the instance (ixf) and net (nxf) reference files.
Forking: agdsPrep -V -rundir /NICIEC2023/lvs_test/boost_lower/query_output -outdir /tmp/qrc_202144/Design -sch -df2 -e /NICIEC2023/lvs_test/boost_lower/query_output/Design.gds.mapesign.alm,Design.ilf -pl Design.ports -mcell /tmp/qrc_202144/Design/Design.mcl -l /NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/lvsfile -w /tmp/qrc_202144/Design/boost_lower.hcl:/tmp/qrc_202144/Design/Design.hcl,/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt:/tmp/qrc_202144/Design/Design.dcl -i Design.ixf,Design.lph,Design.sphesign.gdx -n Design.nxf,Design.stlesign.gnx -s Design_pin_xy.spi:Design.xcn,hccidtmfile
Forking:  /opt/cadence/EXT151/tools.lnx86/extraction/bin/64bit//capgen -techdir /NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL -lvs /tmp/qrc_202144/Design/Design.xcn -p2lvs /NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/qrcTechFile -reseqn -sw3d -length_units meters -cap_unit 1 -cap_ground_layer psub_all -dsub rwell,nwell,pwell,NDRN,NDRF,PDRF,NWHT,WN,WP,swell,swell_all,nwht_ring,dnwell,sd_dnw,hvbn_nwht_wn,hvbn_dnw,hvbn_nwht,nwht_wn,nwht_wn_rh,wp_pcr,DDN,nwht_hole,dnwd_psub,pnpcoll,psub_all -p poly,allGates,ndiff -canonical_res_caps -canonical_res_cap_by_device res_rpdif_ckt,res_rndif_ckt,res_rppo_ckt,res_rnpo_ckt,res_rnpo_3t_ckt_pw,res_rnpo_3t_ckt_nw,res_rppo_3t_ckt_nw,res_rppo_3t_ckt_pw,res_rpdifsab_ckt,res_rndifsab_ckt,res_rpposab_ckt,res_rpposab_3t_ckt_nw,res_rpposab_3t_ckt_pw,res_rnposab_ckt,res_rnposab_3t_ckt_pw,res_rnposab_3t_ckt_nw,res_rhrpo_ckt,res_rhrpo_3t_ckt_nw,res_rhrpo_3t_ckt_pw,res_rhrp_hv_ckt,res_rhrp_hv_3t_ckt,res_rnwaa_ckt,res_rnwsti_ckt,res_rnwaa5v_ckt,res_rnwsti5v_ckt,efgate -blocking nsd:+0.001,ndiff,FOX -blocking ntd:+0.001,ndiff,FOX -blocking psd:+0.001,ndiff,FOX -blocking ptd:+0.001,ndiff,FOX -blocking wn_ntd:+0.001,ndiff,FOX -blocking wn_psd:+0.001,ndiff,FOX -blocking wp_nsd:+0.001,ndiff,FOX -blocking wp_ptd:+0.001,ndiff,FOX -blocking n350_d:+0.001,ndiff,FOX -blocking n400_d:+0.001,ndiff,FOX -blocking ndrf_psd:+0.001,ndiff,FOX -blocking pdrf_nsd:+0.001,ndiff,FOX -blocking pdrf_ptd:+0.001,ndiff,FOX -blocking nwht_ntd:+0.001,ndiff,FOX -blocking ndrn_ntd:+0.001,ndiff,FOX -blocking ndrf_ntd:+0.001,ndiff,FOX -blocking ld_ntd:+0.001,ndiff,FOX -blocking ld_ptd:+0.001,ndiff,FOX -blocking ldnsd_wp_src:+0.001,ndiff,FOX -blocking ldnsd_wp_drn:+0.001,ndiff,FOX -blocking ldnsd_drn:+0.001,ndiff,FOX -blocking ldnsd_rwell_src:+0.001,ndiff,FOX -blocking ldnsd_rwell_drn:+0.001,ndiff,FOX -blocking ldnsd_src:+0.001,ndiff,FOX -blocking ldpsd_src:+0.001,ndiff,FOX -blocking ldpsd_drn:+0.001,ndiff,FOX -blocking ldntd_ddn:+0.001,ndiff,FOX -blocking ldnsd_pcr_src:+0.001,ndiff,FOX -blocking ldpsd_wn_src:+0.001,ndiff,FOX -blocking ldpsd_hvbn_drn:+0.001,ndiff,FOX -blocking wn_psd_drn:+0.001,ndiff,FOX -blocking nde6g5_d:+0.001,ndiff,FOX -blocking sd_ntd:+0.001,ndiff,FOX -blocking res_rpdif_ckt:+0.001,ndiff,FOX -blocking res_rnpo_3t_ckt_pw:+0.001,ndiff,FOX -blocking res_rnpo_3t_ckt_nw:+0.001,ndiff,FOX -blocking res_rppo_3t_ckt_pw:+0.001,ndiff,FOX -blocking res_rppo_3t_ckt_nw:+0.001,ndiff,FOX -blocking res_rpposab_3t_ckt_nw:+0.001,ndiff,FOX -blocking res_rpposab_3t_ckt_pw:+0.001,ndiff,FOX -blocking res_rnposab_3t_ckt_pw:+0.001,ndiff,FOX -blocking res_rnposab_3t_ckt_nw:+0.001,ndiff,FOX -blocking res_rhrpo_3t_ckt_nw:+0.001,ndiff,FOX -blocking res_rhrpo_3t_ckt_pw:+0.001,ndiff,FOX -blocking res_rhrp_hv_3t_ckt:+0.001,ndiff,FOX -blocking res_rndif_ckt:+0.001,ndiff,FOX -blocking res_rpdifsab_ckt:+0.001,ndiff,FOX -blocking res_rndifsab_ckt:+0.001,ndiff,FOX -blocking res_rnwaa_ckt:+0.001,ndiff,FOX -blocking res_rnwsti_ckt:+0.001,ndiff,FOX -blocking res_rnwaa5v_ckt:+0.001,ndiff,FOX -blocking res_rnwsti5v_ckt:+0.001,ndiff,FOX -genericMos ngate18_ckt,D,G,S -genericMos nntgate18_ckt,D,G,S -genericMos ngate50_ckt,D,G,S -genericMos nntgate50_ckt,D,G,S -genericMos pgate18_ckt,D,G,S -genericMos pgate50_INFO (LBMISC-215205):
*** Cadence Quantus QRC Extraction Techgen -trans VERSION 15.1.0 Linux 64 bit - (Thu Jun 11 23:12:18 PDT 2015)  ***
INFO (CAPGEN-41199):
Techgen -trans results will be written to directory: /tmp/qrc_202144/Design
INFO (CAPGEN-41737): Lvs layers dzener55w7l7_0hvbn dzener55w7l7_0wohvbn dzener65w3l3_0hvbn dzener65w3l3_0wohvbn mom_0terminal12 mom_0terminal13 mom_0terminal14 mom_0terminal23 mom_0terminal24 mom_0terminal34 n350ckt_0mark n400ckt_0mark npnemit18a100 npnemit18a100_0ckt npnemit18a25 npnemit18a25_0ckt npnemit18a4 npnemit18a4_0ckt npnemit50a100 npnemit50a100_0ckt npnemit50a25 npnemit50a25_0ckt npnemit50a4 npnemit50a4_0ckt npnwnpepihbna100 npnwnpepihbna100_0ckt npnwnpepihbna25 npnwnpepihbna25_0ckt npnwnpepihbna4 npnwnpepihbna4_0ckt pnpemit18a100 pnpemit18a100_0ckt pnpemit18a25 pnpemit18a25_0ckt pnpemit18a4 pnpemit18a4_0ckt pnpemit50nwa100 pnpemit50nwa100_0ckt pnpemit50nwa25 pnpemit50nwa25_0ckt pnpemit50nwa4 pnpemit50nwa4_0ckt pnpemit50nwdnwa100 pnpemit50nwdnwa100_0ckt pnpemit50nwdnwa25 pnpemit50nwdnwa25_0ckt pnpemit50nwdnwa4 pnpemit50nwdnwa4_0ckt sdmte20_0anode sdmte30_0anode are not mapped in layer_setup file
ckt,D,G,S -genericMos ngate18dnw_ckt,D,G,S -genericMos ngate50dnw_ckt,D,G,S -genericMos pgate18dnw_ckt,D,G,S -genericMos pgate50dnw_ckt,D,G,S -genericMos ngate18dnw_4t_ckt,D,G,S -genericMos ngate50dnw_4t_ckt,D,G,S -genericMos pgate18dnw_4t_ckt,D,G,S -genericMos pgate50dnw_4t_ckt,D,G,S -genericMos ngate100_ckt,D,G,S -genericMos ngate120_ckt,D,G,S -genericMos ngate200_ckt,D,G,S -genericMos ngate350_no_hvbn_ckt,D,G,S -genericMos ngate350_ckt,D,G,S -genericMos ngate400_ckt,D,G,S -genericMos pgate100_ckt,D,G,S -genericMos pgate120_ckt,D,G,S -genericMos pgate200_ckt,D,G,S -genericMos pgate350_ckt,D,G,S -genericMos pgate400_ckt,D,G,S -genericMos nldgate5g5h_ckt,D,G,S -genericMos nldgate5g5_ckt,D,G,S -genericMos nldgate4g5h_ckt,D,G,S -genericMos nldgate4g5_ckt,D,G,S -genericMos pldgate5g5_ckt,D,G,S -genericMos pldgate4g5_ckt,D,G,S -genericMos ngate120_ckt_rx,D,G,S -genericMos ngate200_ckt_rx,D,G,S -genericMos nldgate5ga_hvbn_ckt,D,G,S -genericMos nldgate5ga_wohvbn_ckt,D,G,S -genericMos pldgate5ga_hvbn_ckt,D,G,S -genericMos pldgate5ga_wohvbn_ckt,D,G,S -genericMos ngate100_wohvbn_ckt,D,G,S -genericMos ngate200_wohvbn_ckt,D,G,S -genericMos ngate400_wohvbn_ckt,D,G,S -genericMos pgate100_wohvbn_ckt,D,G,S -genericMos pgate200_wohvbn_ckt,D,G,S -genericMos pgate350_wohvbn_ckt,D,G,S -genericMos pgate400_wohvbn_ckt,D,G,S -genericMos nldgate5g5h_hvbn_ckt,D,G,S -genericMos nldgate5g5_hvbn_ckt,D,G,S -genericMos pldgate5g5_hvbn_ckt,D,G,S -genericMos nldgate4g5h_hvbn_ckt,D,G,S -genericMos nldgate4g5_hvbn_ckt,D,G,S -genericMos pldgate4g5_hvbn_ckt,D,G,S -genericMos ngate120_ckt_rx_wohvbn,D,G,S -genericMos ngate200_ckt_rx_wohvbn,D,G,S -genericMos nldgate12g5h_ckt,D,G,S -genericMos nldgate12g5_ckt,D,G,S -genericMos pldgate12g5_ckt,D,G,S -genericMos pgate90_hvbn_ckt,D,G,S -genericMos pgate90_wohvbn_ckt,D,G,S -genericMos pgate160_hvbn_ckt,D,G,S -genericMos pgate160_wohvbn_ckt,D,G,S -genericMos pgate240_hvbn_ckt,D,G,S -genericMos pgate240_wohvbn_ckt,D,G,S -genericMos pgate280_hvbn_ckt,D,G,S -genericMos pgate280_wohvbn_ckt,D,G,S -genericMos nde6g5_hvbn_seed,D,G,S -genericMos nde6g5_wohvbn_seed,D,G,S -genericMos pde6g5_hvbn_seed,D,G,S -genericMos pde6g5_wohvbn_seed,D,G,S -genericMos nld40g5frx_wohvbn_seed,D,G,S -genericMos nld36g5frx_wohvbn_seed,D,G,S -genericMos nld28g5frx_wohvbn_seed,D,G,S -genericMos nld28g5frx_hvbn_seed,D,G,S -genericMos nld24g5frx_wohvbn_seed,D,G,S -genericMos nld24g5frx_hvbn_seed,D,G,S -genericMos nld16g5frx_wohvbn_seed,D,G,S -genericMos nld16g5frx_hvbn_seed,D,G,S -genericMos nld9g5frx_wohvbn_seed,D,G,S -genericMos nld9g5frx_hvbn_seed,D,G,S /tmp/qrc_202144/Design
WARNING (RCXSPIC-28081): no via between lyrs 'metal4' & 'metal3'; Via effect ignored. Remove the 2 layers for -add_via_effect
INFO (RCXSPIC-27112): via layer via3a does not map to any vias and is ignored
INFO (RCXSPIC-27112): via layer via3c does not map to any vias and is ignored
INFO (RCXSPIC-27112): via layer via4 does not map to any vias and is ignored
INFO (RCXSPIC-27112): via layer via5 does not map to any vias and is ignored
The supplied design data will be treated as a HIERARCHICAL design
Successfully created RCX script '/tmp/qrc_202144/Design/boost_lower/rcx.sh'
Successfully created hierarchical RCX script '/tmp/qrc_202144/Design/rcx.sh'
INFO (LBRCXM-581): Checked out '1' license(s) for Virtuoso_QRC_Extraction_L 15.10
INFO (LBRCXM-608): Executing command
   /opt/cadence/EXT151/tools.lnx86/extraction/bin/64bit//assura_rcx -V  /tmp/qrc_202144/Design/rcx.sh
INFO (ASSREXT-35013):
     ***    assura_rcx VERSION 15.1.0 Linux 64 bit - (Thu Jun 11 23:12:18 PDT 2015)    ***
        * Copyright (c) 2023 Cadence Design Systems, Inc. *
        *                All Rights Reserved                  *
        *          THIS IS UNPUBLISHED PROPRIETARY          *
        *  INFORMATION OF Cadence Design Systems, Inc.           *
        *           THE COPYRIGHT NOTICE DOES NOT          *
        *               EVIDENCE PUBLICATION                  *
set -e
set -v
##ADD_EXPLICIT_VIAS=N
##ADD_BULK_TERMINAL=N
##AGDS_FILE=/dev/null
##AGDS_LAYER_MAP_FILE=/NICIEC2023/lvs_test/boost_lower/query_output/Design.gds.map
##HCCI_DEV_PROP_FILE=/dev/null
##AGDS_SPICE_FILE=/dev/null
##AGDS_TEXT_LAYERS=
##ARRAY_VIAS_SPACING=
##ASSURA_RUN_DIR=.
##ASSURA_RUN_NAME=run1
##BLACK_BOX_CELLS=/dev/null
##BREAK_WIDTH=
##CAP_COUPLING_FACTOR=1.0
##CAP_EXTRACT_MODE=coupled
##CAP_GROUND=0
##CAP_MODELS=yes
##DANGLINGR=N
##DEVICE_FINGER_DELIMITER='@'
##DF2=Y
##DRACULA_RUN_DIR=
##DRACULA_RUN_NAME=
##ENABLESENSITIVITYEXTRACTION=N
##EXCLUDE_FLOAT_LIMIT=
##EXCLUDE_FLOAT_DECOPULING_FACTOR=
##EXCLUDE_FLOATING_NETS=N
##EXCLUDE_NETS_REDUCERC=/dev/null
##EXCLUDE_SELF_CAPS=Y
##IGNORE_GATE_DIFFUSION_FRINGING_CAP=Y
##EXTRACT=both
##EXTRACT_MOS_DIFFUSION_AP=N
##EXTRACT_MOS_DIFFUSION_HIGH=
##EXTRACT_MOS_DIFFUSION_RES=N
##FILTER_SIZE=2.0
##FIXED_NETS_FILE=/dev/null
##FMAX=
##FRACTURE_LENGTH_UNITS=MICRONS
##FREQUENCY_FILE=/dev/null
##GROUND_NETS=
##GROUND_NETS_FILE=/dev/null
##HCCI_DEV_PROP=7
##HCCI_INST_PROP=6
##HCCI_NET_PROP=5
##HCCI_RULE_FILE=
##HCCI_RUN_DIR=/NICIEC2023/lvs_test/boost_lower/query_output
##HCCI_RUN_NAME=Design
##HEADER_FILE=/dev/null
##HIERARCHY_DELIMITER='/'
##HRCX_CELLS_FILE=/tmp/qrc_202144/Design/boost_lower.hcl
##IMPORT_GLOBALS=Y
##LADDER_NETWORK=N
##LVS_SOURCE=hcci
##M_FACTORR=
##M_FACTORW=N
##MACRO_CELL=Y
##MAX_FRACTURE_LENGTH=infinite
##MAX_SIGNALS=
##MERGE_PARALLEL_R=N
##MINC=1e-17
##MINC_BY_PERCENTAGE=0.1
##MINR=0.001
##NET_NAME_SPACE=layout
##NETS_FILE=/dev/null
##NP=1
##OUTPUT=/tmp/qrc_202144/Design/extview.tmp
##OUTPUT_NET_NAME_SPACE=schematic
##PARASITIC_BLOCKING_DEVICE_CELLS_FILE=/NICIEC2023/smic18_Bulk_1P6M_TM1_TM2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev2_0_cciqrc/CCI_QRC/rulefiles/TYPICAL/preserveCellList.txt
##PARASITIC_CAP_MODELS=no
##PARASITIC_RES_MODELS=comment
##PARASITIC_RES_LENGTH=N
##PARASITIC_RES_WIDTH=N
##PARASITIC_RES_WIDTH_DRAWN=N
##PARASITIC_RES_UNIT=N
##PARTIAL_CAP_BLOCKING=N
##PEEC=N
##PIN_ORDER_FILE=/dev/null
##PIPE_ADVGEN=
##PIPE_SPICE2DB=
##POWER_NETS=
##POWER_NETS_FILE=/dev/null
##RC_FREQUENCY=
##RCXDIR=/tmp/qrc_202144/Design
##RCXFS_HIGH=N
##RCXFS_NETS_FILE=/dev/null
##RCXFS_TYPE=none
##RCXFS_CUTOFF_DISTANCE=
##RCXFS_VIA_OFF=N
##REDUCERC=N
##REGION_LIMIT=
##RES_MODELS=yes
##RISE_TIME=
##SAVE_FILL_SHAPES=N
##SINGLE_CAP_EDSPF=N
##SHOW_DIODES=N
##SKIN_FREQUENCY=
##SPEF=N
##SPEF_UNITS=
##SPLIT_PINS=N
##FORCE_SUBCELL_PIN_ORDERS=N
##SPLIT_PINS_DISTANCE=
##SUB_NODE_CHAR='#'
##SUBSTRATE_PROFILE=/dev/null
##SUBSTRATE_STAMPING_OFF=N
##TEMPDIR=/tmp/qrc_202144/Design/rcx_temp
##TEMPERATURE=25.0
##TYPE=full
##USER_REGION=/dev/null
##VARIANT_CELL_FILE=/dev/null
##VIA_EFFECT_OFF=N
##VIRTUAL_FILL=
##XREF=/tmp/qrc_202144/Design/Design.gnx,/tmp/qrc_202144/Design/Design.gdx
##XY_COORDINATES=c,r
CASE_SENSITIVE=TRUE
export CASE_SENSITIVE
setTempDir /tmp/qrc_202144/Design/rcx_temp
DEVICE_FINGER_DELIMITER=@
HIERARCHY_DELIMITER=/
cd /tmp/qrc_202144/Design
cat <<ENDCAT> caps2dversion
* caps2d version: 11
ENDCAT
cat <<ENDCAT> genDev
M ngate50_0ckt-10 - 1 2 3
M pgate50_0ckt-14 - 1 2 3
M ngate50dnw_04t_0ckt-20 - 1 2 3
M pgate400_0wohvbn_0ckt - 1 2 3
ENDCAT
cat <<ENDCAT> flattransUnit.info
meters
ENDCAT
QRC=Y
export QRC
# Generate RCX input data from annotated GDS2 database
agds2rcx -H satfile -r /tmp/qrc_202144/Design/Design.xcn -crundir \
        /NICIEC2023/lvs_test/boost_lower/query_output -add0_net gnd! -unit \
        meters -df2 -xgl -hcells_file Design.hcl -sc hrcx_all_cells_file -pl \
        Design.ports -f Design.alm -lnn Design.lnn -pnet 5 -pinst 6 -pdev 7 \
        Design.agf Design_pin_xy.spi
INFO (AGDSEXT-30090): Device property feature is activated by the existence of the file '/NICIEC2023/lvs_test/boost_lower/query_output/Design.props'
+ERROR (LBMISC-215479): at "agds2rcx": syntax error in file /NICIEC2023/lvs_test/boost_lower/query_output/Design.ports, line 15
ERROR (LBMISC-215251): Error: command failed with status 1
ERROR (LBRCXM-609): Bad return status from RCX run. 0xff00
INFO (LBRCXM-709): *****  Quantus QRC terminated abnormally  *****
ports文件如下
# SVDB: Port Table (ports) (File format 1)
# SVDB: Layout Primary boost_lower
# SVDB: Rules -0 /NICIEC2023/lvs_test/boost_lower/_SMIC_CalLVS_018MS_and_BCD_1850100120200350400_V1.14_REV2_0.lvs_ Sun May 14 11:39:17 2023
# SVDB: GDSII -0 /NICIEC2023/lvs_test/boost_lower/boost_lower.calibre.db Sun May 14 11:39:17 2023
# SVDB: SNL -0 _source.net_
# SVDB:
# SVDB:
# SVDB:
# SVDB:
# SVDB: End of header.
vbp2 1 vbp2 204647 -56740 metal1
VDD 2 VDD 285216 -5946 metal1
vbn2 4 vbn2 262408 -92889 metal1
vil- 6 vil- 322400 -80200 metal3
vil+ 7 vil+ 327500 -82584 metal3
vo_low 10 vo_low 204904 -81795 metal1
VSS 11 VSS 283113 -250643 metal1
vbn1 12 vbn1 204528 -73850 metal1
vbp1 13 vbp1 287307 -27248 metal1
发表于 2023-8-15 11:58:30 | 显示全部楼层
请问楼主解决了吗,这是什么问题?
 楼主| 发表于 2023-8-17 22:45:44 | 显示全部楼层
解决了,QRC这边端口的命名不能带+ -之类的符号,把vi+和vi-改成vip和vim就行了
GMT+8, 2025-12-21 21:22 , Processed in 0.015311 second(s), 4 queries , Gzip On, Redis On.
