查看: 6844|回复: 14
[求助] PEX提取寄生参数后后仿显示net error
发表于 2023-5-13 18:01:30 | 显示全部楼层 |阅读模式
悬赏100资产已解决
之前后仿都没问题,改了testbench的一个输入信号源后,后仿突然显示net error。前仿没有问题,重新提取寄生参数依旧不行。
具体报错如下:
Begin Incremental Netlisting May 13 17:50:32 2023
ERROR (OSSHNL-153): Failed to initialize incremental netlisting because the run directory contains
netlist data from the previous netlisting session which has a corrupt global
map structure file '/home/Huang_L/simulation/31_CISCOC/Bias_Stackv2_tb/adexl/results/data/Interactive.5/1/31_CISCOC:Bias_Stackv2_tb:1/netlist/ihnl/globalmap'. Remove the "ihnl" and "map" directories from the
current run directory and netlist again.
"ERROR (OSSHNL-512): Failed to generate netlist because incremental netlisting data from the previous session is corrupt or missing. Clean the run directory and netlist the entire design.\n"
End netlisting May 13 17:50:32 2023
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
      ...unsuccessful.
最佳答案
查看完整内容
"ERROR (OSSHNL-512): Failed to generate netlist because incremental netlisting data from the previous session is corrupt or missing. Clean the run directory and netlist the entire design.\n" 这个报错需要重新生产网表,在ADE L里Simulation-Netlist-Recreate
发表于 2023-5-13 18:01:31 | 显示全部楼层
发表于 2023-6-20 14:55:09 | 显示全部楼层
楼主找到原因了吗,我也出现了这种情况
发表于 2023-6-20 16:07:08 | 显示全部楼层
重启了一下,换了一下simulation地址可以了
发表于 2023-11-1 15:27:59 | 显示全部楼层
thank you. 666
发表于 2023-11-1 15:29:04 | 显示全部楼层
perfect
发表于 2024-4-20 11:59:44 | 显示全部楼层
请问怎么换simulation地址啊?小白一个,一直没解决这个问题
发表于 2024-6-14 14:57:40 | 显示全部楼层
请问怎么换地址呀
发表于 2024-10-6 19:34:11 | 显示全部楼层
cuihaofeng 发表于 2024-6-14 14:57
请问怎么换地址呀
解决了嘛?
怎么更换地址啊
发表于 2024-11-18 15:10:18 | 显示全部楼层
KYT 发表于 2024-10-6 19:34
解决了嘛?
请问怎么解决
GMT+8, 2025-12-21 03:45 , Processed in 0.025441 second(s), 4 queries , Gzip On, Redis On.
