楼主 |
发表于 2023-5-10 19:23:12
显示全部楼层
2)这种warning,是因为原lib的问题吗?
Warning: SIS-WARNING: leakage_power model for when:default supply:VSS not recharacterized, copied as it is.(NAND2BV0_12TH40)
Warning: SIS-WARNING: rise_power model none:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:A1->ZN)
Warning: SIS-WARNING: fall_power model none:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:A1->ZN)
Warning: SIS-WARNING: rise_power model none:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:B1->ZN)
Warning: SIS-WARNING: fall_power model none:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:B1->ZN)
Warning: SIS-WARNING: rise_power model !B1:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:A1)
Warning: SIS-WARNING: fall_power model !B1:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:A1)
Warning: SIS-WARNING: rise_power model A1&ZN:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:B1)
Warning: SIS-WARNING: fall_power model A1&ZN:VSS not recharacterized, Deleted.(NAND2BV0_12TH40:B1)
Warning: SIS-WARNING: Attribute 'max_transition' of pin 'NAND2BV0_12TH40::A1' has not been updated, hence copied it from seed lib
Warning: SIS-WARNING: Attribute 'max_transition' of pin 'NAND2BV0_12TH40::B1' has not been updated, hence copied it from seed lib
