查看: 2481|回复: 1
[求助] 晶体振荡器仿真问题
发表于 2023-3-6 23:10:06 | 显示全部楼层 |阅读模式
在仿真晶体振荡器时出现了一些问题。振荡器tran分析时正常起振,但进行PSS+Pnoise仿真时出现错误,给出的错误原因如下: ERROR (SPCRTRF-15052): The user-provided period (frequency) estimate appears to be too short (high). This can be due to any the following reasons:
            1, the estimate was wrong.
            2, the oscillator did not start properly.
            3, the numerical damping reduced signal amplitudes
但PSS换成traponly时不会报错(改之前用的gear2only),但Pnoise曲线异常。但振荡器做减幅振荡时,后续稳定在一个非常小的幅度振荡,此时PSS+Pnoise(使用gear2noly)分析时,PSS仿真不会报错。
请问各位大佬这是啥情况啊?
发表于 2025-11-7 20:59:37 | 显示全部楼层
同问,请问楼主解决了吗
GMT+8, 2025-12-27 00:14 , Processed in 0.012519 second(s), 4 queries , Gzip On, Redis On.
