查看: 2441|回复: 3
[求助] cordic算法 在modelsim中complie失败
发表于 2023-2-23 15:15:12 | 显示全部楼层 |阅读模式
testvench文件
`timescale 1 ns/1 ns
module cordic_atan_tb();
//时钟周期,单位为ns,可在此修改时钟周期。
parameter CYCLE    = 20;
//复位时间,此时表示复位3个时钟周期的时间。
parameter RST_TIME = 3 ;
// Inputs
reg                                         clk_50M;
reg                                         rst_n;
reg                                                ena;
reg                  [31:0]                 x;
reg                  [31:0]                 y;
//reg                  [31:0]                 x_in;
//reg                  [31:0]                 y_in;
//wire             [31:0]      finished;
wire             [31:0]      atan;
// Instantiate the Unit Under Test (UUT)
Cordic_atan uut(
        .clk_50M  (clk_50M        ),
    .rst_n    (rst_n        ),
    .x        (x                ),
        .y        (y        ),
        .ena    (ena     ),
        .finished (finished        ),
        .atan     (atan                )
            //生成本地时钟50M
            initial begin
                clk_50M = 0;
                forever
                #(CYCLE/2)
                clk_50M=~clk_50M;
            end
            //产生复位信号
            initial begin
                rst_n = 1;
                #2;
                rst_n = 0;
                #(CYCLE*RST_TIME);
                rst_n = 1;
            end
            //输入信号din0赋值方式
            initial begin
               #50;
                x = 0;
                y = 1000;
                ena  = 1;
                 while(x<=1000)begin
                 #380;
                 x<=x+2'b10;
                 y<=y-2'b10;
                 end
            end
            endmodule
module Cordic_atan
        clk_50M,rst_n,
    x,
        y,
        ena ,
        finished,
        atan
input                                                   clk_50M;
input                                                   rst_n;
input                 [31:0]     x;
input                 [31:0]     y;
input           [31:0]   ena ;
output          [31:0]        finished;
output                [31:0]                 atan;
`define angle_0  32'd2949120   //45°*2^16
`define angle_1  32'd1740992 //26.5651°*2^16
`define angle_2  32'd919872  //14.0362°*2^16
`define angle_3  32'd466944   //7.1250°*2^16
`define angle_4  32'd234368   //3.5763°*2^16
`define angle_5  32'd117312   //1.7899°*2^16
`define angle_6  32'd58688   //0.8952°*2^16
`define angle_7  32'd29312   //0.4476°*2^16
`define angle_8  32'd14656   //0.2238°*2^16
`define angle_9  32'd7360    //0.1119°*2^16
`define angle_10 32'd3648    //0.0560°*2^16
`define angle_11 32'd1856        //0.0280°*2^16
`define angle_12 32'd896    //0.0140°*2^16
`define angle_13 32'd448    //0.0070°*2^16
`define angle_14 32'd257    //0.0035°*2^16
`define angle_15 32'd128    //0.0018°*2^16
parameter Pipeline = 16;
parameter K = 32'h09b74;        //K=0.607253*2^16,32'h09b74,
reg signed         [31:0]                 atan;
reg signed         [31:0]                 x0=0,y0=0,z0=0;
reg signed         [31:0]                 x1=0,y1=0,z1=0;
reg signed         [31:0]                 x2=0,y2=0,z2=0;
reg signed         [31:0]                 x3=0,y3=0,z3=0;
reg signed         [31:0]                 x4=0,y4=0,z4=0;
reg signed         [31:0]                 x5=0,y5=0,z5=0;
reg signed         [31:0]                 x6=0,y6=0,z6=0;
reg signed         [31:0]                 x7=0,y7=0,z7=0;
reg signed         [31:0]                 x8=0,y8=0,z8=0;
reg signed         [31:0]                 x9=0,y9=0,z9=0;
reg signed         [31:0]                 x10=0,y10=0,z10=0;
reg signed         [31:0]                 x11=0,y11=0,z11=0;
reg signed         [31:0]                 x12=0,y12=0,z12=0;
reg signed         [31:0]                 x13=0,y13=0,z13=0;
reg signed         [31:0]                 x14=0,y14=0,z14=0;
reg signed         [31:0]                 x15=0,y15=0,z15=0;
reg signed         [31:0]                 x16=0,y16=0,z16=0;
reg signed      [31:0]          x_in=0,y_in=0,z_in=0;
reg  [5:0]           count;
always@ (posedge clk_50M or negedge rst_n) begin
        if(!rst_n)
          count <= 6'b000000;
        else if( ena  )
          begin
                if( count!=6'b010010 )
                     count <= count+6'b000001;
                else if( count == 6'b010010 )
                    count <= 0;
          end
        else
          count <= 6'b000000;
end
assign finished = (count == 6'b010010)?1'b1:1'b0;
        if(!rst_n)
             begin
                  x_in<= 1'b0;
                  y_in<= 1'b0;
                  z_in<= 1'b0;
             end
        else begin
        if(ena)
            begin                        //?0???????????
                case ({x[31],y[31]})                //????
                        2'b00:
                        begin                                //1??
                            x_in <= x;
                            y_in <= y;
                        end
                        2'b10:
                        begin                                //2??
                            x_in<= -x;
                            y_in<= y;
                        end
                        2'b11:
                        begin                                //3??
                            x_in<= -x;
                            y_in <= -y;
                        end
                        2'b01:
                        begin                                //4??
                            x_in <= x;
                            y_in <= -y;
                        end
                endcase
            end
always @ (posedge clk_50M or negedge rst_n)
begin
        if(!rst_n)
           begin
                x0 <= 1'b0;
                y0 <= 1'b0;
                z0 <= 1'b0;
           end
        else
           begin
                x0 <= x_in<<16;
                y0 <= y_in<<16;
                z0 <= 32'd0;
           end
end
begin
        if(!rst_n)
        begin
                x1 <= 1'b0;
                y1 <= 1'b0;
                z1 <= 1'b0;
        end
        else if(y0[31]==1'b1)//Di is -1;
        begin
      x1 <= x0 - y0;
      y1 <= y0 + x0;
      z1 <= z0 - `angle_0;
        end
        else
        begin  //Di is 1;
      x1 <= x0 + y0;
      y1 <= y0 - x0;
      z1 <= z0 + `angle_0;
        end
end
begin
        if(!rst_n)
        begin
                x2 <= 1'b0;
                y2 <= 1'b0;
                z2 <= 1'b0;
        end
        else if( y1[31]==1'b1)
   begin
        x2 <= x1 - (y1 >>> 1);
        y2 <= y1 + (x1 >>> 1);
        z2 <= z1 - `angle_1;
   end
   else
   begin
       x2 <= x1 + (y1 >>> 1);
       y2 <= y1 - (x1 >>> 1);
       z2 <= z1 + `angle_1;
   end
end
begin
        if(!rst_n)
        begin
                x3 <= 1'b0;
                y3 <= 1'b0;
                z3 <= 1'b0;
        end
        else if( y2[31]==1'b1)
   begin
       x3 <= x2 - (y2 >>> 2);
       y3 <= y2 + (x2 >>> 2);
       z3 <= z2 - `angle_2;
   end
   else
   begin
       x3 <= x2 + (y2 >>> 2);
       y3 <= y2 - (x2 >>> 2);
       z3 <= z2 + `angle_2;
   end
end
begin
        if(!rst_n)
        begin
                x4 <= 1'b0;
                y4 <= 1'b0;
                z4 <= 1'b0;
        end
        else if( y3[31]==1'b1)
   begin
       x4 <= x3 - (y3 >>> 3);
       y4 <= y3 + (x3 >>> 3);
       z4 <= z3 - `angle_3;
   end
   else
   begin
       x4 <= x3 + (y3 >>> 3);
       y4 <= y3 -(x3 >>> 3);
       z4 <= z3 + `angle_3;
   end
end
begin
        if(!rst_n)
        begin
                x5 <= 1'b0;
                y5 <= 1'b0;
                z5 <= 1'b0;
        end
        else if( y4[31]==1'b1)
   begin
       x5 <= x4 - (y4 >>> 4);
       y5 <= y4 + (x4 >>> 4);
       z5 <= z4 -`angle_4;
   end
   else
   begin
       x5 <= x4 + (y4 >>> 4);
       y5 <= y4 - (x4 >>> 4);
       z5 <= z4 + `angle_4;
   end
end
begin
        if(!rst_n)
        begin
                x6 <= 1'b0;
                y6 <= 1'b0;
                z6 <= 1'b0;
        end
        else if( y5[31]==1'b1)
   begin
       x6 <= x5 - (y5 >>> 5);
       y6 <= y5 + (x5 >>> 5);
       z6 <= z5 - `angle_5;
   end
   else
   begin
       x6 <= x5 + (y5 >>> 5);
       y6 <= y5 - (x5 >>> 5);
       z6 <= z5 + `angle_5;
   end
end
begin
        if(!rst_n)
        begin
                x7 <= 1'b0;
                y7 <= 1'b0;
                z7 <= 1'b0;
        end
        else if(y6[31]==1'b1)
   begin
       x7 <= x6 - (y6 >>> 6);
       y7 <= y6 + (x6 >>> 6);
       z7 <= z6 - `angle_6;
   end
   else
   begin
       x7 <= x6 + (y6 >>> 6);
       y7 <= y6 - (x6 >>> 6);
       z7 <= z6 + `angle_6;
   end
end
begin
        if(!rst_n)
        begin
                x8 <= 1'b0;
                y8 <= 1'b0;
                z8 <= 1'b0;
        end
        else if(y7[31]==1'b1)
   begin
       x8 <= x7 - (y7 >>> 7);
       y8 <= y7 + (x7 >>> 7);
       z8 <= z7 - `angle_7;
   end
   else
   begin
       x8 <= x7 + (y7 >>> 7);
       y8 <= y7 - (x7 >>> 7);
       z8 <= z7 + `angle_7;
   end
end
begin
        if(!rst_n)
        begin
                x9 <= 1'b0;
                y9 <= 1'b0;
                z9 <= 1'b0;
        end
        else if(y8[31]==1'b1)
   begin
       x9 <= x8 - (y8 >>> 8);
       y9 <= y8 + (x8 >>> 8);
       z9 <= z8 - `angle_8;
   end
   else
   begin
       x9 <= x8 + (y8 >>> 8);
       y9 <= y8 - (x8 >>> 8);
       z9 <= z8 + `angle_8;
   end
end
begin
        if(!rst_n)
        begin
                x10 <= 1'b0;
                y10 <= 1'b0;
                z10 <= 1'b0;
        end
        else if( y9[31]==1'b1)
   begin
       x10 <= x9 - (y9 >>> 9);
       y10 <= y9 + (x9 >>> 9);
       z10 <= z9 - `angle_9;
   end
   else
   begin
       x10 <= x9 + (y9 >>> 9);
       y10 <= y9 - (x9 >>> 9);
       z10 <= z9 + `angle_9;
   end
end
begin
        if(!rst_n)
        begin
                x11 <= 1'b0;
                y11 <= 1'b0;
                z11 <= 1'b0;
        end
        else if( y10[31]==1'b1)
   begin
       x11 <= x10 - (y10 >>> 10);
       y11 <= y10 + (x10 >>> 10);
       z11 <= z10 - `angle_10;
   end
   else
   begin
       x11 <= x10 + (y10 >>> 10);
       y11 <= y10 - (x10 >>> 10);
       z11 <= z10 + `angle_10;
   end
end
begin
        if(!rst_n)
        begin
                x12 <= 1'b0;
                y12 <= 1'b0;
                z12 <= 1'b0;
        end
        else if(y11[31]==1'b1)
   begin
       x12 <= x11 - (y11 >>> 11);
       y12 <= y11 + (x11 >>> 11);
       z12 <= z11 - `angle_11;
   end
   else
   begin
       x12 <= x11 + (y11 >>> 11);
       y12 <= y11 - (x11 >>> 11);
       z12 <= z11 + `angle_11;
   end
end
begin
        if(!rst_n)
        begin
                x13 <= 1'b0;
                y13 <= 1'b0;
                z13 <= 1'b0;
        end
        else if( y12[31]==1'b1)
   begin
       x13 <= x12 - (y12 >>> 12);
       y13 <= y12 + (x12 >>> 12);
       z13 <= z12 - `angle_12;
   end
   else
   begin
       x13 <= x12 + (y12 >>> 12);
       y13 <= y12 - (x12 >>> 12);
       z13 <= z12 + `angle_12;
   end
end
begin
        if(!rst_n)
        begin
                x14 <= 1'b0;
                y14 <= 1'b0;
                z14 <= 1'b0;
        end
        else if( y13[31]==1'b1)
   begin
       x14 <= x13 - (y13 >>> 13);
       y14 <= y13 + (x13 >>> 13);
       z14 <= z13 - `angle_13;
   end
   else
   begin
       x14 <= x13 + (y13 >>> 13);
       y14 <= y13 - (x13 >>> 13);
       z14 <= z13 + `angle_13;
   end
end
begin
        if(!rst_n)
        begin
                x15 <= 1'b0;
                y15 <= 1'b0;
                z15 <= 1'b0;
        end
        else if(y14[31]==1'b1)
   begin
       x15 <= x14 - (y14 >>> 14);
       y15 <= y14 + (x14 >>> 14);
       z15 <= z14 - `angle_14;
   end
   else
   begin
       x15 <= x14 + (y14 >>> 14);
       y15 <= y14 - (x14 >>> 14);
       z15 <= z14 + `angle_14;
   end
end
begin
        if(!rst_n)
        begin
                x16 <= 1'b0;
                y16 <= 1'b0;
                z16 <= 1'b0;
        end
        else if( y15[31]==1'b1)
   begin
       x16 <= x15 - (y15 >>> 15);
       y16 <= y15 + (x15 >>> 15);
       z16 <= z15 - `angle_15;
   end
   else
   begin
       x16 <= x15 + (y15 >>> 15);
       y16 <= y15 - (x15 >>> 15);
       z16 <= z15 + `angle_15;
   end
end
begin
        if(!rst_n)
          begin
                atan <= 1'b0;
          end
        else if(finished)
                        2'b00:
                        begin                                //1??
                           atan=z16<<16
                        end
                        2'b10:
                        begin                                //2??
                           atan=(z16<<16)+90
                        end
                        2'b11:
                        begin                                //3??
                           atan=(z16<<16)+180
                        end
                        2'b01:
                        begin                                //4??
                           atan=(z16<<16)+270
                        end
                endcase
          end
endmodule
出现错误描述
出现错误描述
发表于 2023-2-23 16:29:26 | 显示全部楼层
代码没行号怎么看啊兄弟
发表于 2023-2-23 16:30:23 | 显示全部楼层
就是基础语法,什么begin end 没对上之类的,兄弟自己检查检查吧
 楼主| 发表于 2023-2-23 17:46:17 | 显示全部楼层
谢谢!!确实是这样!!
GMT+8, 2025-12-30 01:34 , Processed in 0.018976 second(s), 5 queries , Gzip On, Redis On.
