查看: 2485|回复: 1
[求助] blowup parameter的问题
发表于 2023-2-10 16:47:34 | 显示全部楼层 |阅读模式
请问cadence里面的blowup parameter在哪里设置啊??
 楼主| 发表于 2023-2-10 16:54:50 | 显示全部楼层
我在仿真pss的时候会报这样的错误Error found by spectre at time = 3.25521 ps during transient analysis `tran'.
    Signal V(I0.C5.cap.hn1) = 22.1835 GV exceeds the blowup limit for the
        quantity `V' which is (1 GV). It is likely that the circuit is
        unstable. If you really want signals this large, set the `blowup'
        parameter of this quantity to a larger value.
需要设置一下blowup parameter,现在就是不知道这个参数在哪个地方设置。
GMT+8, 2025-12-13 17:23 , Processed in 0.022940 second(s), 3 queries , Gzip On, Redis On.
