查看: 1261|回复: 4
[求助] the risc-v reader上面的这段话应该怎么理解?
发表于 2023-1-19 12:16:48 | 显示全部楼层 |阅读模式
If software uses an omitted RISC-V instruction from an optional extension, the hardware traps and executes the desired function in software as part of a standard library.
这是啥意思啊?
发表于 2023-1-27 22:33:32 | 显示全部楼层
I think of it as a way to use test instructions that haven't been implemented yet in hardware. Good idea actually.
 楼主| 发表于 2023-1-28 07:00:09 | 显示全部楼层
gliss6306 发表于 2023-1-27 22:33
I think of it as a way to use test instructions that haven't been implemented yet in hardware. Good  ...
硬件没有实现,软件怎样执行呢?
发表于 2023-1-30 04:38:08 | 显示全部楼层
orientview 发表于 2023-1-28 07:00
硬件没有实现,软件怎样执行呢?
You implement the hardware instructions in software. When the software tries to execute the unimplemented instruction the CPU traps and will call a function instead, the function that's called is defined with instructions that the CPU can execute, when the function returns, the instruction is done. I don't think RISC-V is the first to do this.
 楼主| 发表于 2023-1-30 14:40:17 | 显示全部楼层
gliss6306 发表于 2023-1-30 04:38
You implement the hardware instructions in software. When the software tries to execute the unimpl ...
那这个hardware trap的功能岂不是要很强大?可以接受很多ISA之外的指令?
有具体的实现原理和电路吗?
GMT+8, 2025-10-27 03:33 , Processed in 0.014907 second(s), 3 queries , Gzip On, Redis On.
