查看: 4165|回复: 2
Simerics MP 5.2 x64 Full Features
发表于 2023-1-6 06:17:48 | 显示全部楼层 |阅读模式
Simerics MP 5.2 x64
Simerics-MP software is a set of core 3D CFD capabilities and physics modules that enable accurate virtual testing for multi-purpose (MP) applications including single-phase or multiphase flow, turbulence, cavitation/aeration, heat and mass transfer, particles and interaction . Performs fluid and structure.  Simerics-MP solves multiphase flow and heat transfer using a volume of fluid (VOF) approach with a high-resolution interface capture algorithm.  Both implicit and explicit methods are fast and robust with clear phase interfaces and excellent
Singing the finite volume RANS approach, Simerics-MP solves compressible and incompressible, calm and turbulent, internal and external, steady and unsteady fluid flows.  The solver covers all flow velocities from creeping flow to supersonic flow.  It also solves fluid non-Newaston well as fluid with variable properties such as real gas.  Simerics-MP has a generic masher.  It generates body-fit binary tree mesh directly and automatically from CAD surfaces.  No need to clean CAD.  User can always get a valid mesh even with default settings.  The mesher also provides easy and intuitive ways to modify the mesh in a user-defined area.  The produced mesh has very high quality and very high efficiency.
Features and features of the Simerics-MP program:
  • Comprehensive physics
  • Accurate predictions
  • Fast model creation, even faster simulation speed
  • Capable of modeling complex details down to the micro scale
  • Multiphase flow (MP FLOW)
  • MP MESHING
  • Multi-phase cavitation (MP CAVITATION)
  • Multiphase heat (MP HEAT
If you are interested in the full licensed software Simerics MP 5.2 x64 with full feature license and tutorial examples, then do well to contact    fast.forever24@gmail.com
PLEASE NOTE
Also, if you are interested in other EDA software like: EMPIRE XPU 8.1.3 , Remcom XFDTD 7.10.1, Remcom XGTD 3.1.2, Remcom Wireless Insite 3.3.5, Remcom WaveFarer Radar Software 2.1, Sonnet Suite Pro 18.56 and ASN Filter Designer 5.2.1, Tetcos Netsim Professional 13.1, DigacSilent 2022, VPI Photonic TransmissionMaker 11.1, Optenni Lab 5.0, EMTP-RV 4.2.1, SpiceVision 7.0 and StarVision etc. please contact  fast.forever24@gmail.com
发表于 2023-10-22 12:13:53 | 显示全部楼层
联系8020169@qq.com
给用户测试,完美
发表于 2023-10-22 13:09:58 | 显示全部楼层
thanks
GMT+8, 2025-12-24 00:32 , Processed in 0.014637 second(s), 4 queries , Gzip On, Redis On.
