查看: 1809|回复: 6
[求助] 求助下载一篇论文
发表于 2023-1-5 18:40:20 | 显示全部楼层 |阅读模式
An 18-Bit Incremental Zoom ADC with Reduced Delay Overhead Data Weighted Averaging for Battery Measurement Systems
  • 342 Accesses
Part of the Lecture Notes in Electrical Engineering book series (LNEE,volume 722)
AbstractThe paper presents a systematic implementation of 18-bit incremental zoom ADC for stacked lithium-ion battery voltage monitoring system with a reduced dynamic range analog front-end that comprises a resistive level shifter. A comparative study of the incremental zoom ADC and its incremental ADC counterpart, for a given modulator order, is presented in detail. The choice of incremental zoom ADC is demonstrated to be a best fit for an 18-bit resolution of the target application. Multi-bit DAC non-linearity is proven to be major bottleneck for the ADC performance. The performance of data weighted averaging (DWA) dynamic element matching (DEM) technique for improvising modulator linearity with 0.1 percent DAC component mismatch is analyzed. DWA DEM is confirmed to meet an in-band SNDR of 108 dB, operating on a 250 kHz oversampled clock frequency, required for 18-bit modulator linearity with a 5-bit DAC. An SNR of 114 dB is achieved with the first-stage integrator thermal noise limited to 3.3 µVrms over process voltage and temperature variations (PVT) using 0.35 µm CMOS process.
发表于 2023-1-5 21:03:16 | 显示全部楼层
IEEE和学校图书馆资源里都搜不到。
发表于 2023-1-5 23:05:22 | 显示全部楼层
见附件,
venk.pdf
1020.5 KB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2023-1-6 15:22:11 | 显示全部楼层
 楼主| 发表于 2023-1-6 16:23:14 | 显示全部楼层
axel 发表于 2023-1-5 23:05
见附件,
谢谢。
发表于 2023-1-8 14:39:47 | 显示全部楼层
发表于 2023-1-8 16:40:12 | 显示全部楼层
thanks
GMT+8, 2025-11-18 08:05 , Processed in 0.357064 second(s), 4 queries , Gzip On, Redis On.
