查看: 2131|回复: 9
[求助] 关于ATPG的报错,哪位大神知道 吗
发表于 2023-1-5 09:20:30 | 显示全部楼层 |阅读模式
报的是N2错误,unsupported construct (specify not supported). (N2-1)
发表于 2023-1-5 10:51:45 | 显示全部楼层
warning,可以先不管,直接跑完看啊可能。
 楼主| 发表于 2023-1-5 11:50:01 | 显示全部楼层
所有warning都 不管吗?我只是想学习下为什么会有这些错,
发表于 2023-1-5 15:12:09 | 显示全部楼层
tmax里,man N2,会有介绍的,文档中说可以不用管。
 楼主| 发表于 2023-1-5 15:57:48 | 显示全部楼层
好的,谢谢,我再问一个问题,刚一个warning : undrivern module inoutpin(MTONFI4DIO/POC )  我查了下netlist模块MTONFI4DIO里没并没POC 这个pin.但在相应的Library model的MTONFI4DIO里却有POC。这个要怎么解决?
发表于 2023-1-5 17:28:52 | 显示全部楼层
这是B7 warning,netlist和库文件不匹配,你说要修改netlist还是库文件?
 楼主| 发表于 2023-1-5 17:47:15 | 显示全部楼层
懂了,谢谢,再问一个问题哈,下面那个错是怎么来的,要怎么才能解决Warning: Pin D0 of MUX gate with inverted data inputs could not be placed anywhere, dropped design view of U_digcore/U_sdc_U_bus_state_ctrl_U_bus_state_normal_U635 with 2 pins (B22-1)
Warning: Pin PAD of internal BUS could not be placed anywhere, dropped design view of U_pad/U_SWDIO with 1 pins (B22-2)
Warning: Pin PAD of internal BUS could not be placed anywhere, dropped design view of U_pad/U_SWCLK with 1 pins (B22-3)
Warning: Pin PAD of internal BUS could not be placed anywhere, dropped design view of U_pad/U_SMCLK with 1 pins (B22-4)
Warning: Pin PAD of internal BUS could not be placed anywhere, dropped design view of U_pad/U_SMCMD with 1 pins (B22-5)
Warning: Pin PAD of internal BUS could not be placed anywhere, dropped design view of U_pad/U_SMIO0 with 1 pins (B22-6)
Warning: Pin PAD of internal BUS could not be placed anywhere, dropped design view of U_pad/U_SMIO1 with 1 pins (B22-7)
发表于 2023-1-6 09:25:02 | 显示全部楼层
首先B22 warning不用管,顶多影响一点点test coverage。至于这个warning的根本原因,你可以man一下B22,文档中也没有提到解决方案。
 楼主| 发表于 2023-1-6 09:31:38 | 显示全部楼层
greatao 发表于 2023-1-6 09:25
首先B22 warning不用管,顶多影响一点点test coverage。至于这个warning的根本原因,你可以man一下B22,文 ...
好的,谢谢
发表于 2023-2-1 09:29:14 | 显示全部楼层
这个是pad 的poc 功能, 不影响正常的function, 可以忽略 ~~~
GMT+8, 2025-12-26 09:57 , Processed in 0.024099 second(s), 5 queries , Gzip On, Redis On.
