查看: 2385|回复: 5
[求助] 带着upf跑DC时报错:Error: The target_library does not contain an inverter characterized for operating conditio...
发表于 2023-1-1 22:26:14 | 显示全部楼层 |阅读模式
upf内容如下:
create_power_domain TOP_DOMAIN
create_supply_port VDD
create_supply_port VSS
create_supply_net VDD
create_supply_net VSS
connect_supply_net VDD   -port {VDD}
connect_supply_net VSS   -port {VSS}
set_domain_supply_net TOP_DOMAIN -primary_power_net VDD    -primary_ground_net VSS
add_port_state VDD   -state {LV 0.84}
add_port_state VSS   -state {ON 0.0}
                        -state {OFF off}
create_pst design_pst -supplies {VDD VSS}
add_pst_state design_work -pst design_pst -state {LV ON}
# tcl中设置电压
set_voltage 0.84 -object_list VDD
set_voltage 0.0  -object_list VSS
报错内容如下(1个warning,2个error):
Warning: Ports found with no related supply net. This might cause simulation/synthesis/verification mismatch. (UPF-405)
Information: Total 0 repeater cells are inserted. (UPF-464)
Information: A total of 0 isolation cells are inserted. (UPF-214)
This problem occurred at:
    <top design>
Error: The target_library does not contain an inverter characterized for operating condition (voltage = 0.840000V, process = 1.200000, temperature = 125.000000). (MV-006)
    <top design>
Error: The target library does not contain an inverter.
        An inverter is required for mapping. (OPT-101)
0
发表于 2023-1-3 09:25:25 | 显示全部楼层
只看log报错的意思应该就是dc map的时候发现在给的器件库里面找不到给定条件下的反相器。
 楼主| 发表于 2023-1-5 18:28:05 | 显示全部楼层
mgc455 发表于 2023-1-3 09:25
只看log报错的意思应该就是dc map的时候发现在给的器件库里面找不到给定条件下的反相器。 ...
如何解决呢?求赐教
发表于 2023-1-11 15:50:25 | 显示全部楼层
yuming_ziyi 发表于 2023-1-5 18:28
如何解决呢?求赐教
读的库的可能不是0.84V的,导入的是worst的库吗?
 楼主| 发表于 2023-1-14 21:00:45 | 显示全部楼层
库用的sc_max.db这个,应该怎么看这个库支持的电压?
发表于 2023-2-8 15:18:34 | 显示全部楼层
好久了,看有没有lib,这个是可读的,或者看文档,max一般指的就是ss conner。
GMT+8, 2025-12-21 08:51 , Processed in 0.019730 second(s), 3 queries , Gzip On, Redis On.
