查看: 4337|回复: 12
[资料] TIGFET10nm Open Source Predictive Process Design Kit v1.0
发表于 2022-12-6 17:59:32 | 显示全部楼层 |阅读模式
Copyright (c) [2019] [Laboratory for NanoIntegrated Systems]
This repository is a process design kit for Cadence Virtuoso® describing a TIGFET 10nm silicon nanowire device technology. The design kit is derived using Synopsys Sentaurus TCAD® based device simulations.
This kit consists of a SPICE model and full custom physical design files including a Design Rule Manual, a Design Rule Check, and a Layout Versus Schematic decks for Mentor Graphics Calibre®.
TIGFET10nm PDK Directory Structure
calibre/ -> SVRF rules for Mentor Graphics Calibre®
cdslib/ -> Technology libraires for Cadence Virtuoso and setup scripts
hspice/ -> Simulation models for Synopsys HSPICE®
doc/ -> Documentation
For more detail about the key assumptions made while designing this PDK, please refer to the following publication:
Ganesh Gore, Patsy Cadareanu, Edouard Giacomin, and Pierre-Emmanuel Gaillardon "A Predictive Process Design Kit for Three-Independent-Gate Field-Effect Transistors", 2019 IFIP/IEEE 27th International Conference on Very Large Scale Integration (VLSI-SoC), 6-9 October 2019.
Design Kit Installation and Usage (assuming a csh/tcsh shell)
1. Clone the github repository.
  1. git clone https://github.com/LNIS-Projects/TIGFET-10nm-PDK.git
  2. cd TIGFET-10nm-PDK
    复制代码
2. Set the variable PDK_DIR to where the PDK folder is.
  1. setenv PDK_DIR "$PWD"
    复制代码
3.Copy the required user files to where you want to start Virtuoso®. It is assumed here that Virtuoso is started in the Github folder itself.
  1. source $PDK_DIR/cdslib/setup/setup.csh
    复制代码
Note that this script copies all of the required user files (.cdsinit, cds.lib, and Calibre® runset files) to the current working directory if they do not already exist.
4.Source your setup scripts for Cadence Virtuoso®, Mentor Graphics Calibre®, and Synopsys HSPICE® and launch Cadence Virtuoso® using the provided script:
  1. source launch_tigfet10nm.sh
    复制代码
In case of any doubts/questions/suggestions, please raise issue on GitHub or send an email to pierre-emmanuel.gaillardon@utah.edu or ganesh.gore@utah.edu.
TIGFET-10nm-PDK-ganesh_dev.zip (2.1 MB , 下载次数: 30 )
TIGFET-10nm-PDK-layout-tigfet15nm.zip (3.09 MB , 下载次数: 28 )
TIGFET-10nm-PDK-drc-updates.zip (2.73 MB , 下载次数: 28 )
TIGFET-10nm-PDK-master.zip (2.73 MB , 下载次数: 28 )
TIGFET-10nm-PDK-logic-gates.zip (3.47 MB , 下载次数: 28 )
定版号版本,与前面的相比多了calibre用的检查规则文件。 下载完删除最后的那个.gz后缀命
TIGFET-10nm-PDK-v1.0.zip.gz.013.gz (17.12 MB , 下载次数: 27 )
TIGFET-10nm-PDK-v1.0.zip.gz.012.gz (30 MB , 下载次数: 29 ) TIGFET-10nm-PDK-v1.0.zip.gz.010.gz (30 MB , 下载次数: 27 )
TIGFET-10nm-PDK-v1.0.zip.gz.009.gz (30 MB , 下载次数: 27 )
TIGFET-10nm-PDK-v1.0.zip.gz.011.gz (30 MB , 下载次数: 33 )
TIGFET-10nm-PDK-v1.0.zip.gz.008.gz (30 MB , 下载次数: 27 )
TIGFET-10nm-PDK-v1.0.zip.gz.007.gz (30 MB , 下载次数: 28 )
TIGFET-10nm-PDK-v1.0.zip.gz.006.gz (30 MB , 下载次数: 25 )
TIGFET-10nm-PDK-v1.0.zip.gz.005.gz (30 MB , 下载次数: 37 )
TIGFET-10nm-PDK-v1.0.zip.gz.004.gz (30 MB , 下载次数: 27 )
TIGFET-10nm-PDK-v1.0.zip.gz.003.gz (30 MB , 下载次数: 27 )
TIGFET-10nm-PDK-v1.0.zip.gz.002.gz (30 MB , 下载次数: 30 )
TIGFET-10nm-PDK-v1.0.zip.gz.001.gz (30 MB , 下载次数: 27 )
发表于 2022-12-6 20:31:34 | 显示全部楼层
多谢分享
发表于 2022-12-6 20:57:52 | 显示全部楼层
谢谢分享
发表于 2022-12-7 16:58:16 | 显示全部楼层
谢谢分享!!
发表于 2022-12-16 10:06:11 | 显示全部楼层
Tx for sharing , learning is good..
发表于 2023-4-17 15:25:54 | 显示全部楼层
感谢分享
发表于 2024-3-17 20:38:06 | 显示全部楼层
感谢分享
发表于 2024-3-31 01:45:40 | 显示全部楼层
感谢分享
发表于 2024-3-31 01:50:48 | 显示全部楼层
感谢分享
发表于 2024-3-31 01:51:38 | 显示全部楼层
感谢分享
GMT+8, 2025-12-24 21:52 , Processed in 0.034562 second(s), 4 queries , Gzip On, Redis On.
