查看: 4042|回复: 10
[资料] FreePDK3 Predictive Process Design Kit
发表于 2022-12-6 02:26:23 | 显示全部楼层 |阅读模式
FreePDK3 TM Predictive Process Design Kit
  version 1.0 (2021-08-30)
  Copyright (c) 2021 North Carolina State University, All Rights Reserved.
  Please see the file LICENSE in this directory for license. You may not use these files except in compliance with the License.
Welcome to the FreePDK TM 3nm Free, Open-Source Process Design Kit
  This initiative is brought to you by NC State Univeristy and Synopsys.
  This version of the kit was created by the following at NC State University:
        Sushant Sadangi - Design Rules, Layer Stack, and ICV Rules
        Viswanatha Pasumarthy - Star-RC Models
        W. Shepherd Pitts - HSPICE Models
        W. Rhett Davis - Custom Compiler Support and Project Management
  Many thanks to the following at Synopsys for technical and financial support:
        Ron Duncan - Process technology advice and ICV Support
        Luis Francisco & Yen-Sung Chen - ICV Rules Templates and Coding Support
        Olaf Schneider - Custom Compiler PDK and Scripting Support
        Jonathan White & Patrick Haspel - Project Management
Quick Design Kit Usage Instructions
  1. Create or modify the file lib.defs in your current directory and ensure that it includes the following line:
  1. INCLUDE $PDK_DIR/syncust/lib.defs
    复制代码
       ...where $PDK_DIR is replaced with the path to the directory containing this file. Note that the environmnet variable PDK_DIR does not need to be set.
  2. Source your setup scripts for Synopsys Custom Compiler, IC Validator, Star-RC, HSPICE, and Custom WaveView
  3. Start Synopsys Custom Compiler with the command
  1. custom_compiler &
    复制代码
Contents
Directory Contents
syncust/ Technology libraries and scripts for Synopsys Custom Compiler
icv/ DRC and LVS rules for Synopsys IC Validator
starrc/ Parasitic extraction models for Synopsys StarRC
hspice/ Simulation models for Synopsys HSPICE
examples/ Example library with layouts and schematics
doc/ Design Rule Manual and Release Notes
More documentation and tutorials for this kit can be found at http://www.eda.ncsu.edu/FreePDK
Please send all questions and comments to eda_help@ncsu.edu
FreePDK3-1.0.zip (29.04 MB , 下载次数: 62 ) FreePDK3-A Novel PDK for Physical Verification at the 3nm Node.pdf (4.29 MB , 下载次数: 77 )
发表于 2022-12-6 09:33:13 | 显示全部楼层
感谢分享
发表于 2022-12-6 10:57:31 | 显示全部楼层
謝謝。感恩。
 楼主| 发表于 2022-12-6 14:13:12 | 显示全部楼层
另有官方配套教程但由于涉及版权被删,在本帖在次上传。如再删可去NCSU大学下载 Custom Digital Tutorials | NC State EDA (ncsu.edu)
FreePDK3 Full Custom Digital Design Tutorials.z01.zip (20 MB , 下载次数: 22 )
FreePDK3 Full Custom Digital Design Tutorials.z02.zip (20 MB , 下载次数: 25 )
FreePDK3 Full Custom Digital Design Tutorials.zip (1.43 MB , 下载次数: 26 )
发表于 2022-12-6 20:45:00 | 显示全部楼层
多谢分享
发表于 2022-12-7 22:38:08 | 显示全部楼层
thanks
发表于 2022-12-16 15:17:04 | 显示全部楼层
Thank you..
发表于 2022-12-16 15:24:11 | 显示全部楼层
轩辕志瑜 发表于 2022-12-6 14:13
另有官方配套教程但由于涉及版权被删,在本帖在次上传。如再删可去NCSU大学下载 Custom Digital Tutorials  ...
Great!..
发表于 2022-12-27 10:33:33 | 显示全部楼层
niccccccccccce tnx for learning..
发表于 2023-1-13 11:16:45 | 显示全部楼层
这个pdk集成到openroad了吗
GMT+8, 2025-12-21 14:10 , Processed in 0.022323 second(s), 3 queries , Gzip On, Redis On.
