查看: 3900|回复: 6
[求助] cdsinfo.tag文件是什么
发表于 2022-11-28 14:28:28 | 显示全部楼层 |阅读模式
悬赏20资产已解决
求大佬解释cdsinfo.tag文件的作用,以及与cds.lib文件的区别
最佳答案
查看完整内容
cdsinfo.tag 设置表明设计数据库是否纳入SOS的管理 cds.lib 库等路径设置文件
发表于 2022-11-28 14:28:29 | 显示全部楼层
cds.lib  库等路径设置文件
 楼主| 发表于 2022-11-28 14:55:18 | 显示全部楼层
cds.lib  库等路径设置文件
在做SOS管理系统时,生成工作区会产生这个文件,除了这种情况,还有其他情况会产生这个文件吗
发表于 2022-11-28 15:03:14 | 显示全部楼层
zw123456 发表于 2022-11-28 14:55
在做SOS管理系统时,生成工作区会产生这个文件,除了这种情况,还有其他情况会产生这个文件吗 ...
会啊,这是cadence的关联支持文件,别的工具也可以生成、使用
发表于 2022-11-28 17:19:21 | 显示全部楼层
# This is a cdsinfo.tag file.
# See the "Cadence Application Infrastructure Reference Manual" for
# details on the format of this file, its semantics, and its use.
# The `#' character denotes a comment. Removing the leading `#'
# character from any of the entries below will activate them.
# CDSLIBRARY entry - add this entry if the directory containing
# this cdsinfo.tag file is the root of a Cadence library.
# CDSLIBRARY
# CDSLIBCHECK - set this entry to require that libraries have
# a cdsinfo.tag file with a CDSLIBRARY entry. Legal values are
# ON and OFF. By default (OFF), directories named in a cds.lib file
# do not have to have a cdsinfo.tag file with a CDSLIBRARY entry.
# CDSLIBCHECK ON
# DMTYPE - set this entry to define the DM system for Cadence's
# Generic DM facility. Values will be shifted to lower case.
# DMTYPE none
# DMTYPE crcs
# DMTYPE tdm
# DMTYPE sync
# NAMESPACE - set this entry to define the library namespace according
# to the type of machine on which the data is stored. Legal values are
# `LibraryNT' and
# `LibraryUnix'.
# NAMESPACE LibraryUnix
CDSLIBRARY
DMTYPE none
发表于 2022-11-28 17:20:15 | 显示全部楼层
抓了一个pdk下面的cdsinfo.tag.可以瞅一下。
 楼主| 发表于 2022-11-30 15:42:30 | 显示全部楼层
好的,感谢
GMT+8, 2025-12-18 12:13 , Processed in 0.020839 second(s), 4 queries , Gzip On, Redis On.
