楼主: shindziharan
C* IC_618
发表于 2022-12-6 21:30:46 | 显示全部楼层
感谢分享
发表于 2022-12-9 16:21:14 | 显示全部楼层
Thanks for sharing
发表于 2022-12-26 03:40:21 | 显示全部楼层
I got an error message:
ERROR (LMF-02008): License call failed for feature 111, version 6.180 and quantity 1. The license server search path is defined as /opt/cadence/license/license.dat. The FLEXnet error message is as follows,     FLEXnet ERROR(-8, 0, 0): Invalid (inconsistent) license key.  Run 'lic_error LMF-02008' for more information..
ERROR (ELI-00138) Failed to launch application because license '111' cannot be checked out.
Does anyone know what the problem is?
Thanks in advance.
 楼主| 发表于 2022-12-26 04:17:36 | 显示全部楼层
ERROR (LMF-02008): License call failed for feature 111, version 6.180 and q ...
As a guess:
1) You haven't patched your software. (it is obvious that the software will not work).
2) You patched the software using a too old patch. (it is obvious that the software will not work).
3) You patched the software using a more or less modern patch, and for some reason you are using a licensed daemon: a) old; b) new; -- doesn't matter, stop doing it... After the patch, you no longer need a licensed daemon.
4) You are using an outdated license file. (sometimes it is necessary to specify the software version in the license file... in some case, for features related to IC, version 6.18 should be specified).
发表于 2022-12-26 05:41:21 | 显示全部楼层
thank you for your sharing
发表于 2022-12-26 08:14:48 | 显示全部楼层
thanks!!!
发表于 2022-12-30 17:29:06 | 显示全部楼层
大哥你太猛了,厉害厉害
发表于 2023-1-3 03:19:37 | 显示全部楼层
Can you share last medicine for Cadence products ?
发表于 2023-1-3 10:16:18 | 显示全部楼层
顶一下
发表于 2023-1-5 16:48:02 | 显示全部楼层
Why charged me 2 times?
GMT+8, 2025-9-15 05:31 , Processed in 0.016391 second(s), 3 queries , Gzip On, Redis On.
