查看: 2309|回复: 1
[求助] ASIC 时钟mux约束
发表于 2022-11-15 17:12:41 | 显示全部楼层 |阅读模式
悬赏200资产未解决
各位大侠,请问下面这种情况该如何约束?
#源时钟定义
create_clock –name clk1 –period <> [get_portsclk1]
create_clock –name clk2 –period <> [get_portsclk2]
create_clock –name clk3 –period <> [get_portsclk3]
set_clock_groups –logically_exclusive –group{ clk_mux1_1} –group { clk_mux1_2} –group { clk_mux1_3}
#FFdiv1生成时钟定义
create_generate_clock –name clk_div_1 –divide_by2 –source [get_pins FFDdiv1_ck] –master_clock [get_clocks clk1] [get_pins FFDdiv1_q]
create_generate_clock –name clk_div_2 –divide_by2 –source [get_pins FFDdiv1_ck] –master_clock [get_clocks clk2] [get_pins FFDdiv1_q]–add
create_generate_clock –name clk_div_3 –divide_by2 –source [get_pins FFDdiv1_ck] –master_clock [get_clocks clk3] [get_pins FFDdiv1_q]–add
set_clock_groups –physically_exclusive –group{ clk_div_1} –group { clk_div_2} –group { clk_div_3}
#FFdiv2 FFdiv3生成时钟如何定义,特别是master_clock怎么设置?
 楼主| 发表于 2022-11-15 17:23:52 | 显示全部楼层
或者是这样的思路,mux1输出定义3个时钟,DDdiv1输出定义3个时钟,mux2输出定义3+3=6个时钟,FFdiv2输出定义6个时钟,FFdiv3输出定义6个时钟?
GMT+8, 2025-12-25 14:00 , Processed in 0.020839 second(s), 5 queries , Gzip On, Redis On.
