在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 4054|回复: 5
[求助] verilog A求助
发表于 2022-11-9 00:41:05 | 显示全部楼层 |阅读模式
@( cross(V(outa), +1) ) begin
V(posvgaL) <+ 3.3;
end
有会verilog的前辈给说一下上述代码哪里错了吗?仿真一直报错
ERROR (VACOMP-2157): "...../veriloga/veriloga.va", line 11: Encountered a contribution statement embedded in an analog event. Remove the contribution statement from the analog event.
    ERROR (VACOMP-2157): "...../veriloga/veriloga.va", line 16: Encountered a contribution statement embedded in an analog event. Remove the contribution statement from the analog event.
    ERROR (VACOMP-2157): "..../veriloga/veriloga.va", line 20: Encountered a contribution statement embedded in an analog event. Remove the contribution statement from the analog event.
发表于 2022-11-9 08:21:57 | 显示全部楼层
改成
begin
posvgaL_value = 3.3;
end
V(posvgaL) <+ posvgaL_value;
看看這樣能不能過
发表于 2022-11-9 08:52:57 | 显示全部楼层
2楼对的,<+不是赋值,不能用在cross block里面;
发表于 2022-11-9 09:57:16 | 显示全部楼层
V(posvgaL) <+ 3.3;
这种<+语句不能用在cross函数里
 楼主| 发表于 2022-11-9 10:16:00 | 显示全部楼层
谢谢!
发表于 2023-8-19 20:50:59 | 显示全部楼层
学到了
GMT+8, 2025-8-2 16:23 , Processed in 0.021032 second(s), 7 queries , Gzip On, Redis On.
