查看: 1874|回复: 9
[资料] Circuit Oriented ElectromagneticModeling Using The Peec Techniques Compress
发表于 2022-11-8 09:52:23 | 显示全部楼层 |阅读模式
We have to distinguish between two fundamentally different types of circuit models for
electromagnetics. Some of them are based on a differential equation (DE) formulation of
Maxwell’s equations, while others are based on integral equation (IE) form.
The DE forms are commensurate with the system of equations that results from the formulation
of a problem in terms of DEs. This results in circuit models that have neighborto-
neighbor coupling only. The most well-known form is the finite difference time domain
(FDTD) method, which is a direct numerical solution of Maxwell’s equations. The advantages
of DE methods is that very sparse systems of equation result. At the same time, these
systems are larger than the ones obtained from IE-based methods.
Circuit Oriented ElectromagneticModeling Using The Peec Techniques Compress.pdf
6.45 MB, 下载次数: 48 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2022-11-8 14:36:56 | 显示全部楼层
谢谢分享
发表于 2022-11-8 20:23:57 | 显示全部楼层
多谢分享
发表于 2022-11-8 22:51:04 | 显示全部楼层
kankana
发表于 2022-11-14 13:33:09 | 显示全部楼层
谢谢分享!
发表于 2022-11-14 13:37:54 | 显示全部楼层
谢谢分享
发表于 2022-11-14 13:47:15 | 显示全部楼层
感谢分享
发表于 2022-11-14 13:47:16 | 显示全部楼层
thanks
发表于 2022-12-1 16:06:26 | 显示全部楼层
非常感谢~~~
发表于 2023-7-7 21:44:01 来自手机 | 显示全部楼层
Thanks
GMT+8, 2025-9-19 05:46 , Processed in 0.022770 second(s), 4 queries , Gzip On, Redis On.
