查看: 6098|回复: 8
[求助] primetime报No constrained paths怎么解决
发表于 2022-11-6 16:36:06 | 显示全部楼层 |阅读模式
初学pt,想通过primetime 跑出电路中某些路径的spice网表文件,然后再拿到spice去做老化仿真。是sdc文件写的约束不对吗,还是哪有问题了,小白求助pt跑的tcl脚本如下:
set search_path "/home/crazy/Desktop/example/lab"
set link_path "* NangateOpenCellLibrary_slow.db"
set target_library { NangateOpenCellLibrary_slow.db}
set link_library {* NangateOpenCellLibrary_slow.db}
set design s27
read_verilog /home/crazy/Desktop/example/lab/report/decode_netlist.v
link_design $design
current_design $design
read_sdc decode.sdc
report_timing
write_spice_deck -output fresh_path.spi -sub_circuit_file NangateOpenCellLibrary.spi  -logic_one_voltage 1.8 [get_timing_paths -from [get_port G0] -to [get_port G17]]
sdc文件如下:
  6 set sdc_version 2.0
  7
  8 set_units -time ns -resistance MOhm -capacitance fF -voltage V -current mA
  9 set_max_delay 1.5 -from [get_port G0] -to [get_port G17]]
10 set_min_delay 0.5 -from [get_port G0] -to [get_port G17]]
跑完报错:
pt_shell> source run.tcl
Loading db file '/home/crazy/Desktop/example/lab/NangateOpenCellLibrary_slow.db'
Loading verilog file '/home/crazy/Desktop/example/lab/report/decode_netlist.v'
Information: tri converted to a wire with no special attributes
        at line 12 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
        at line 13 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
        at line 14 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
        at line 15 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
        at line 16 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
        at line 17 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
        at line 18 in /home/crazy/Desktop/example/lab/report/decode_netlist.v (SVR-21)
Linking design s27...
Warning: Unable to resolve reference to 'dff' in 's27'. (LNK-005)
Information: Creating black box for DFF_0/dff... (LNK-043)
Information: Creating black box for DFF_1/dff... (LNK-043)
Information: Creating black box for DFF_2/dff... (LNK-043)
Information: 130 (97.01%) library cells are unused in library NangateOpenCellLibrary..... (LNK-045)
Information: total 130 library cells are unused (LNK-046)
Design 's27' was successfully linked.
Information: There are 22 leaf cells, ports, hiers and 21 nets in the design (LNK-047)
Reading SDC version 2.0...
Warning: Nothing implicitly matched '_sel15]' (SEL-003)
Error: Nothing matched for to_list (SEL-005)
Warning: Nothing implicitly matched '_sel17]' (SEL-003)
Report : timing
        -path_type full
        -delay_type max
        -max_paths 1
        -sort_by slack
Design : s27
Version: M-2016.12-SP1
Date   : Sun Nov  6 01:26:52 2022
No constrained paths.
Information: Checked out license 'PrimeTime-SI' (PT-019)
Error: Nothing matched for collection (SEL-005)
No timing path or timing arc found for the object_list
Information: Defining new variable 'design'. (CMD-041)
发表于 2022-11-7 09:57:30 | 显示全部楼层
你有的path没有setup,所以会报这个。
发表于 2022-11-7 10:06:14 | 显示全部楼层
试一下: set timing_report_unconstrained_paths true(man一下,以防错字)
 楼主| 发表于 2022-11-7 11:59:37 | 显示全部楼层
这个我之前试过,确实是不报No constrained paths了
 楼主| 发表于 2022-11-7 12:06:25 | 显示全部楼层
发表于 2022-11-7 13:52:18 | 显示全部楼层
仙电彭于晏 发表于 2022-11-7 12:06
感谢回复,我查了下资料,发现没有对进行端口约束,设置约束完之后就没有报No constrained paths了。
主要是没有create clock吧
 楼主| 发表于 2022-11-7 15:53:23 | 显示全部楼层
菜鸟一号 发表于 2022-11-7 13:52
主要是没有create clock吧
应该是的
发表于 2022-11-9 10:35:53 | 显示全部楼层
主要是没有create clock吧
你可以用check_timing这种命令来查一下,是不是约束全了,养成一个好习惯
欢迎加wx: pr-hao123,拉你进数字后端群
发表于 2023-10-10 11:00:22 | 显示全部楼层
lz请问能分享一下lab文件吗?
GMT+8, 2025-12-18 16:09 , Processed in 0.022540 second(s), 4 queries , Gzip On, Redis On.
