查看: 9916|回复: 42
[资料] FPGAs and Parallel Architectures for Aerospace Applications Soft Errors and Fault-Tolerant Design @2015
发表于 2022-11-1 21:26:28 | 显示全部楼层 |阅读模式
This book introduces the concepts of soft errors in FPGAs, as well as the motivation for using commercial, off-the-shelf (COTS) FPGAs in mission-critical and remote applications, such as aerospace. The authors describe the effects of radiation in FPGAs, present a large set of soft-error mitigation techniques that can be applied in these circuits, as well as methods for qualifying these circuits under radiation. Coverage includes radiation effects in FPGAs, fault-tolerant techniques for FPGAs, use of COTS FPGAs in aerospace applications, experimental data of FPGAs under radiation, FPGA embedded processors under radiation and fault injection in FPGAs. Since dedicated parallel processing architectures such as GPUs have become more desirable in aerospace applications due to high computational power, GPU analysis under radiation is also discussed.
FPGAs and Parallel Architectures for Aerospace Applications Soft Errors and Faul.pdf (12.22 MB , 下载次数: 86 )
发表于 2022-11-1 21:47:46 | 显示全部楼层
Thanks for sharing
发表于 2022-11-1 22:05:50 | 显示全部楼层
Thanks for sharing
发表于 2022-11-1 22:29:57 | 显示全部楼层
学习
发表于 2022-11-1 22:51:59 | 显示全部楼层
谢谢分享!
发表于 2022-11-1 22:58:06 | 显示全部楼层
Thanks for sharing
发表于 2022-11-2 01:16:33 | 显示全部楼层
thanks
发表于 2022-11-2 03:48:02 | 显示全部楼层
楼主辛苦了
发表于 2022-11-2 06:27:08 | 显示全部楼层
拜读!
发表于 2022-11-2 07:18:21 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-16 15:23 , Processed in 0.021540 second(s), 4 queries , Gzip On, Redis On.
