查看: 6823|回复: 31
[资料] Timing Channels in Cryptography A Micro-Architectural Perspective @2014
发表于 2022-11-1 20:20:06 | 显示全部楼层 |阅读模式
This book deals with timing attacks on cryptographic ciphers. It describes and analyzes various unintended covert timing channels that are formed when ciphers are executed in microprocessors. The book considers modern superscalar microprocessors which are enabled with features such as multi-threaded, pipelined, parallel, speculative, and out-of order execution. Various timing attack algorithms are described and analyzed for both block ciphers as well as public-key ciphers. The interplay between the cipher implementation, the system architecture, and the attacks success is analyzed. Further hardware and software countermeasures are discussed with the aim of illustrating methods to build systems that can protect against these attacks. iShot_2022-11-01_20.16.31.png
Timing Channels in Cryptography A Micro-Architectural Perspective (Chester Rebei.pdf (6.12 MB , 下载次数: 47 )
发表于 2022-11-1 20:30:20 | 显示全部楼层
goooooooooood
发表于 2022-11-1 20:33:06 | 显示全部楼层
thanks
发表于 2022-11-1 20:39:55 | 显示全部楼层
thank you,bro
发表于 2022-11-1 20:48:21 | 显示全部楼层
thank y ou
发表于 2022-11-1 21:13:53 | 显示全部楼层
谢谢分享
发表于 2022-11-1 21:23:58 | 显示全部楼层
kanaknaa
发表于 2022-11-1 21:37:15 | 显示全部楼层
I would like to read the content. Thank you very much.
发表于 2022-11-1 21:40:20 | 显示全部楼层
The book has been downloaded. Thank you very much.
发表于 2022-11-1 21:46:28 | 显示全部楼层
Let me take a look
GMT+8, 2025-12-25 18:34 , Processed in 0.028254 second(s), 5 queries , Gzip On, Redis On.
