查看: 3186|回复: 6
OPEVPN会影响EMX 6.0
发表于 2022-10-26 16:38:22 | 显示全部楼层 |阅读模式
服务器上开OPEVPN服务,EMX跑不起来,报错,停掉OPENVPN就好了,有人直到怎么解?
Interface version: 6.0.0 (29-Oct-2020)
Command line for EMX version 6.0:
/home/eda/cadence/INTEGRAND61/bin/emx
/home/eda/test/EMX_work/testdir_symind_ct.work/symind_ct.gds symind_ct
/home/eda/cadence/INTEGRAND60/virtuoso_ui/emxinterface/processes/generic65.proc
-e 1 -t 1 -v 0.5 --3d=* -p P000=X1 -p P001=P2 -p P002=CT<0> -i P000 -i P001 -i
P002 --sweep 0 2e+10 --sweep-stepsize 1e+08 --verbose=3 --print-command-line -l
2 --cadence-pins=1 --dump-connectivity --quasistatic --dump-connectivity
--parallel=0 --simultaneous-frequencies=2 --recommended-memory --format=psf -s
/home/eda/test/EMX_work/testdir_symind_ct.work/symind_ct.raw -y
/home/eda/test/EMX_work/testdir_symind_ct.work/symind_ct.raw --format=matlab -y
/home/eda/test/EMX_work/testdir_symind_ct.work/symind_ct.raw/symind_ct.y
--format=touchstone -s
/home/eda/test/EMX_work/testdir_symind_ct.work/symind_ct.s%dp
/home/eda/cadence/INTEGRAND60/bin/emx: info: --simultaneous-frequencies=0 is recommended
40 CPUs detected
Using 32 CPUs
Checking out feature "EMX_Solver"...OK
Memory limit of 117.93 GB out of 125.93 GB
CPU supports SSE level 6
Reading GDS file...
Process 35196 signal Segmentation fault at address (nil)
EMX has encountered an unexpected problem.  This represents a software
bug.  Please report this problem to emxsupport@cadence.com.
If you can provide the input files and command-line options used, that
will help us to fix the problem.  This problem occurred with EMX
version 6.0 (5c24dcf).  The command line used to run EMX was:
Backtrace:
0x56e2aa
0x365100f7e0
0x9ad6de
0x9ae4f8
0x99c10e
0x998178
0x9987c2
0x995bc9
0x8bc297
0x8afc5d
0x8afd91
0x8b0497
0x8b8e69
0x8bc968
0x3651007aa1
0x3650ce8c4d
/home/eda/cadence/INTEGRAND60/bin/emx: fatal exception
Process exited abnormally with status 1
发表于 2022-10-26 17:18:32 | 显示全部楼层
有人直到怎么解?+1+1
发表于 2022-10-26 18:32:42 | 显示全部楼层
EMX 跑不起来的时候,会有什么Log文件吗?
或者你查一下license是不是有报错,或者是EMX的license端口与Open VPN冲突。
Other than that,no reason at all.
发表于 2022-10-27 11:45:21 | 显示全部楼层
在License文件中加入TS_OK关键词再试试。
发表于 2022-10-28 10:17:06 | 显示全部楼层
谢谢
发表于 2022-10-28 10:30:50 | 显示全部楼层
OPEVPN服务做啥用的?
 楼主| 发表于 2022-10-28 11:27:27 | 显示全部楼层
cxmcxm666888 发表于 2022-10-28 10:30
OPEVPN服务做啥用的?
是做远程访问的
GMT+8, 2025-12-23 16:51 , Processed in 0.015613 second(s), 3 queries , Gzip On, Redis On.
