查看: 2371|回复: 2
[原创] 帮忙下载一篇此论文,A High-Precision Delta Sigma ADC with Chopper in BMS
发表于 2022-9-1 19:16:33 | 显示全部楼层 |阅读模式
A High-Precision Delta Sigma ADC with Chopper in BMS[url=][/url]
This paper presents a high-precision, low-power Delta Sigma ADC design,using a single-loop fourth-order feedforward modulator structure with anoversampling ratio of 128, which improves the conversion accuracy whilereducing the output range of each integrator. A 5-stage CIC filter is usedto reduce area and power consumption, and the decimation rate isconfigurable to achieve different ...
https://ieeexplore.ieee.org/document/9620517
谢谢。
发表于 2022-9-1 20:44:34 | 显示全部楼层
here
A_High-Precision_Delta_Sigma_ADC_with_Chopper_in_BMS.pdf
1.28 MB, 下载次数: 149 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2022-9-2 09:27:43 | 显示全部楼层
谢谢。
GMT+8, 2025-12-22 14:09 , Processed in 0.019981 second(s), 5 queries , Gzip On, Redis On.
