查看: 3124|回复: 4
[原创] 自己保存一下skill 脚本
发表于 2022-8-26 18:38:32 | 显示全部楼层 |阅读模式
从顶层到底层修改某层layer尺寸
(修改孔要打散)
procedure(HierSizeLayer()
let((cv winid bbox CTlist VIA1list VIA2list VIA3list VIA4list CTlist_new VIAllist_new VIA2list_new VIA3list_new)
cv=geGetEditRep ()
winid=geGetEditCellViewWindow(cv)
if(cv~>mode=="r"
then
geChangeEditMode("a")
;if
bbox=cv~>bBox
CTlist  =  leSearchHierarchy(
cv bbox 0 "rectangle" list( list( "layer" "==" list( "CA" "drawing" )) list( "width" "==" 0.22 ))
VIA1list=leSearchHierarchy(
cv bbox 0 "rectangle" list( list( "layer" "==" list( "V1" "drawing" )) list( "width" "==" 0.26 ))
VIA2list=leSearchHierarchy(
cv bbox 0 "rectangle" list( list( "layer" "==" list( "V2" "drawing" )) list( "width" "==" 0.26 ))
VIA3list=leSearchHierarchy(
cv bbox 0 "rectangle"  list( list( "layer" "==" list( "V3" "drawing" )) list( "width" "==" 0.26 ))
foreach (x CTlist
leSizeShape(x -0.065)
); foreach
foreach (x VIA1list
leSizeShape(x - 0.08)
);foreach
foreach(x VIA2list
leSizeShape (x - 0.08)
);foreach
foreach (x VIA3list
);foreach
CTlist_new    =leSearchHierarchy (
cv bbox  32 "rectangle" list( list( "layer" "==" list( "CA" "drawing" )) list( "width" "==" 0.22 ))
VIA1list_new=leSearchHierarchy(
cv bbox  32 "rectangle"  list( list( "layer" "==" list( "V1" "drawing" )) list( "width" "==" 0.26 ))
VIA2list_new=leSearchHierarchy(
cv bbox 32 "rectangle"   list( list( "layer" "==" list( "V2" "drawing" )) list( "width" "==" 0.26 ))
VIA3list_new=leSearchHierarchy(
cv bbox 32 "rectangle"   list(list( "layer" "=="  list( "V3" "drawing" )) list( "width" "==" 0.26))
geSave ()
instances=filtercell(cv~>instances)
foreach (x instances
geEditInPlace (winid "a" x 0 1 1)
HierSizeLayer()
leReturn()
); foreach
);let
);procedure
procedure(filtercell(objs)
let ( (namelist num nameflag objs_new)
namelist=artUnique (objs~>cellName)
num=length(namelist)
declare (group [num])
nameflag=listToVector(namelist)
objs_new=nil
for(i 0 num-1
group=setof(x objs x->cellName==nameflag)
objs_new=cons (car(group ) objs_new)
); for
reverse (objs_new)
);let
);procedure
 楼主| 发表于 2023-12-21 09:49:15 | 显示全部楼层
发表于 2023-12-21 11:39:56 | 显示全部楼层
谢谢分享
发表于 2024-1-4 14:14:51 | 显示全部楼层
谢谢分享
发表于 2024-1-29 15:11:09 | 显示全部楼层
楼主,请教一下这个artUnique这个函数是干嘛的,以及filtercell这个函数的作用。
GMT+8, 2025-12-14 10:47 , Processed in 0.020245 second(s), 2 queries , Gzip On, Redis On.
